Sun Visor Resto
Discussion in 'Interior Restoration' started by dcozzi, Nov 1, 2020.
  1. dcozzi
    dcozzi Veteran Member
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    The materials were still good but the stitching turned to dust. So far I have hand stitched one. The other represents how it started off. Pretty good I think. Just takes time. Thanks to Tony P, I can find the holes to install them.;)
  2. Twisted_Metal
    30,039
    2,770
    Nice job! :D
    Just out of curiosity...
    How many stitches are in 1970 Camaro visors?
    (Just about every detail about a 70 Camaro is here somewhere but I don’t think I’ve ever seen that one.)
  3. 70-camaro
    70-camaro Veteran Member
    3,555
    2,039
    Mar 25, 2010
    marietta ohio
    Very nice work.
  4. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Thank you.
    I do not know but it takes about 6-8 feet of thread to do one visor and about an hour.
    Cost = About $0.50 of thread.
    Zstar likes this.
  5. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Thank you very much.
  6. Zstar
    Zstar Veteran Member
    2,640
    905
    Mar 23, 2014
    Ocala, Florida
    Great job!
  7. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Does anyone know which visor goes on which side? The part numbers are the same but one says "CAV 1" and the other is "CAV 2"
    The visors I have are otherwise exactly the same. One will have the screw exposed when up, or I have 2 from the same side.
    OK, so the passenger screw is exposed. I do not have a mismatched set in any way. Now, which way does the Dorito shaped base attach to the roof?
  8. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Was not fun cutting into the new headliner I worked so hard on installing but, they are done.
    BillyDean7173 likes this.
  9. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Sizing the wheels.
    The rear was easy and these tires will fit fine in the well.
    The fronts, I have not bought the fronts yet and finding the right wheel measurement is hard. I am using this tool and it tells me a wide tire a lot of others here can run with the stock fenderwells in place will rub the rear of the wheel well when turning. I have been getting some great help on here from
    70-camaro likes this.
  10. Twisted_Metal
    30,039
    2,770
    That’s a lot of tire!
    What wheel width and backspacing will you use with them?
