Suspension re-install question
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 74cam_mojo, Jun 19, 2008.
  1. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    Whats the proper order to reinstall springs / shocks and steering knuckle? I know obviously the spring comes b4 the shock / but should I install the steering knuckle first to the control arms???? the the compressed spring followed by the shock.
    PS; as it stands now both control arms are hangin free
    Any comments would be apreciated / 74 Camaro
  2. John Wright
    15,259
    419
    Aug 9, 2002
    Rustburg, Va
    I bolted up the upper ball joint to the spindle, then slipped the spring in and then brought the lower control arm up and bolted the lower ball joint to the spindle. Then shocks, sway bars...ect....
  3. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    Thank you John
  4. John Wright
    15,259
    419
    Aug 9, 2002
    Rustburg, Va
    keep this in mind when installing the springs....
    This pic is looking up into the subframe from underneath(upper spring bucket)
    and this....
