Suspension upgrade. What bushings
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by dutch73camaro, Jan 31, 2020.
  1. dutch73camaro
    dutch73camaro Veteran Member
    192
    49
    Jan 7, 2016
    Beverwijk, Netherlands
    Hi guys,
    I want to upgrade my suspension of the 73.
    plans
    Beef up stock arms
    Better bushings ? ( but what PU or Steel ? )
    qa1 coilovers
    tall upper ball joints
    I read alot of good things of the delrin bushes but they are damn expensive.
    i have to build the whole car so if i can save a bit...
  2. SPG
    SPG Bumblebee Builder
    1,087
    390
    Sep 1, 2018
    Sacramento
    get bushings from ptfb or customworks and never look back
    While you're at it, get a subframe connector as well, those two things will improve your car immensely
  3. dutch73camaro
    192
    49
    Jan 7, 2016
    also solid subframe bushings ?
    and what about the leafsprings.
    plan is to build a 450 hp smallblock
    can i use stock (new) engine mounts ?
  4. ULTM8Z
    ULTM8Z Veteran Member
    10,059
    868
    May 19, 2000
    Los Angeles
    If you can swing it, I'd ditch the stock upper arms and get some tubular arms... they'll allow you to dial in more caster which will improve handling and steering feel.
    I got my uppers from Performance Online. Very inexpensive and they work great. They come with bushings already installed and with grease fittings.
    Agreed with SPG... subframe connectors are another good add, as well as a set of the G-braces. These three things will completely transform the feel of the car.
  5. SPG
    1,087
    390
    Sep 1, 2018
    Sacramento
  6. dutch73camaro
    192
    49
    Jan 7, 2016
    so much difference between stock with taller joint and solid bushing ?
    it adds up another 400 in stead of make stock better ( i live in the netherlands so shipping and taxes )
    i can order those true atech motorsports ( summit wholesale )
    7081TCA-UKB
    but look slight different
  7. biker
    biker Veteran Member
    3,556
    1,625
    Dec 7, 2014
    You can use the stock clamshell motor mount, but use a new polyurethane insert. Cheap to buy and they really take all the slop out of the engine. Much less movement out of the motor/trans. I also added a polyurethane trans mount which completes the tight feel.
  8. raimond
    raimond Member
    38
    9
    Jan 16, 2020
    Another vote for customworks bushings. Really worth the cost.
  9. Lowend
    16,396
    1,224
    Mar 25, 1999
    San Jose, CA, USA
  10. badazz81z28
    20,733
    1,418
    Alabama
    I would look to Global West. You can find everything on Summit.
