Swapping Thrush 17656 for Dynomax super turbos
Discussion in 'High Performance Modifications' started by 450bench, Oct 14, 2014.
  1. 450bench
    450bench Veteran Member
    3,488
    231
    Feb 25, 2002
    memphis, tn-shelby
    Taking off a pair of fairly new Thrush welded 17656 mufflers for a set of dynomax 17733 super turbos. I'm losing my hearing in my left ear and I'm hoping these quiet the thing down and stop the drone. Anybody have any experience with either of these? Is there a flow difference that anyone is aware of? I think the Thrush mufflers I have are copies of flowmaster 40s.
  2. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Do you have tailpipes?
  3. grzewnicki
    3,578
    277
    Dec 9, 2009
    Gordon from Jacksonville Fl
    My car had Flowmaster 40's on it when I bought it, way too much drone. I put the Super Turbos on and, with tail pipes they were way too quiet. Hardly hear it idle. I swapped them out for Pypes Race Pro, much better sound no drone inside, not too loud.
  4. 450bench
    3,488
    231
    Feb 25, 2002
    memphis, tn-shelby
    Yes
  5. 450bench
    3,488
    231
    Feb 25, 2002
    memphis, tn-shelby
    That's kinda what I'm looking for, something quiet or as quiet as it can be with an 11 to 1 406 and the old 302ho6 cam which is pretty radical.
    These Thrush welded mufflers are loud as hell and the drone is kicking my azz. I do have tail pipes that exit behind the rear tires.
  6. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    I second the Pypes Race Pros. Nice low rumble at idle, no drone at cruise, and they open up when you mash the loud pedal.
  7. 77 cruiser
    77 cruiser Veteran Member
    589
    36
    Nov 17, 2006
    Frostbite Falls MN
    I have the 20 inch case ones on my 385, don't thing they are too quiet.
    Had Blomasters before & they got old.
    Maybe I'm getting old. :eek:
  8. muscl car
    23,356
    1,794
    Jul 8, 2001
    Hendersonville Tennessee
    i would go with Spin techs !!!:)
  9. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    I took off the Flowmaster 50's last year for a set of the Super Turbos. They have the 14" long case and are very quiet at idle. However, they did end up a bit louder under power than I thought they would. Not wot, normal driving at 3000 rpm on the street. I am installing hushmat soon and hope it solves the issue. The FM drone isn't there, but the volume is a bit more than I wanted. HTH. Good luck.
  10. REARSPROCKET
    REARSPROCKET Veteran Member
    916
    Apr 27, 2007
    Gas Fume Heaven, Coastal Northeast, USA
    The DynoMax Welded Ultra-Flo s will work nicely for what you want.
