Sway bar hitting my 9" rear end help
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by alpinemetal, Mar 23, 2020.
  1. badazz81z28
    20,726
    1,417
    Alabama
    I'm curious to see how the car handles with a BBC on the autocross with no rear sway bar.
  2. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,645
    1,060
    Mar 27, 2016
    NY
    Me too!
  3. alpinemetal
    alpinemetal Member
    69
    Jul 5, 2014
    San Diego, CA
    LOL only slightly worse than my 2015 2SS that reacts to every pebble on the road. The 71 has Global West upper and lower control arms with Del-A-Lum bushings and urethane body bushings.
    I've got a 2012 Impala and a 1500 Yukon anyway
  4. dave@ztech
    4,645
    1,060
    Mar 27, 2016
    NY
    If you are going aut crossing, I guess , you will see if the rear sway not being there matters , I would think that at slower speeds it might not matter much??
  5. alpinemetal
    alpinemetal Member
    69
    Jul 5, 2014
    San Diego, CA
    Not sure about Auto Cross here in San Diego County but we have a lot of windy mountain roads to get my driving fix satisfied
    [email protected] likes this.
  6. ks71z28
    ks71z28 Veteran Member Lifetime Gold Member
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    we have a nice clamp on style we designed for this reason, it's way better priced than DSE or Hotchkis
    http://www.customworksproducts.com/suspension.html
  7. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    I'll have to look but I may have some drop links that have been lengthened by about 1-2".
  8. Lowend
    16,395
    1,221
    Mar 25, 1999
    San Jose, CA, USA
    I was afraid you were referencing those. Those are unsafe for hi-performance use.
    Load Carrier and Air-Shocks place the majority of a car’s weight on the upper shock perches, a simple 3/8 hole bored into the upper subframe. The shock perches were never designed to hold any weight, as asking them to take on 2000 LBS of car is a problem waiting to happen.
  9. badazz81z28
    20,726
    1,417
    Alabama
    Pretty much the same design concept as DSE and Hotchkis, but I will say both have re-enforcing braces for both sides of the frame rather than 1. DSE uses ball joint style end links rather than heim joints. I can’t say anything about your kit, but I can see it’s not the same. The consumer will have to weigh cost with benefit.
  10. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    The PTFB adjustable rear bar should clear, we designed it to clear girdle covers, a 9" extends back about 1/2" more than a 10 bolt, girdle covers extend about 1"+, the PTFB bar also requires no fabrication or drilling, it mounts in place of a stock bar.
