Sway bars
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by gs462, Jan 11, 2010.
  1. gs462
    gs462 Veteran Member
    189
    Oct 3, 2009
    chardon ohio
    I read all the stickies and didnt find any definitive answers so I'll ask, are trans am ws6 sway bars bigger/ better than the bars on my 79 z28? I have access to a whole ws6 car a friend is parting.
  2. Gary S
    23,747
    1,428
    Yes, the WS6 TA should have larger bars than your Z28. Your Z28 should have a 1 1/8" front and 5/8" rear. The Trans Ams had 1 1/4" front and 5/8" rear except for the WS6 Trans Ams which had 1 1/4" front and 3/4" rear (most years)
  3. gs462
    189
    Oct 3, 2009
    chardon ohio
    Thank you very much Gary, are they direct bolt ons?
  4. Gary S
    23,747
    1,428
    Yes, direct bolt in as long as you have the correct size bushings to match the swaybars.
  5. gs462
    189
    Oct 3, 2009
    chardon ohio
    Awesome thank you again. All my prior cars were built for the drag strip I want this one to turn corners too. So, I'm in unfamiliar waters here. thanks again for the help.
  6. 79T/Aman
    2,628
    247
    Oct 7, 2004
    Dickson TN.
    with stock rate springs you can also use a 7/8" Trans Am bar those came on earlier cars up to 74 or 75
  7. ks71z28
    ks71z28 Veteran Member Lifetime Gold Member
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    rear bars are your friend, larger the better, and adjustable.... the best suspension tuning device
  8. gs462
    189
    Oct 3, 2009
    chardon ohio
    Thanks KS71 I was looking at your site and was wondering what is the benefit of the taller ball joint?
  9. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    With stiffer front springs I had trouble with a rear bar bigger than 5/8" picking up the inner rear wheel on tight turns autocrossing with road race slicks-or pulling in an angle driveway. So bigger may not be better.
