T-56 clutch master firewall bracket.
Discussion in 'High Tech Retrofits' started by Zedzag, Apr 25, 2009.
  1. Zedzag
    Zedzag Veteran Member
    528
    Jan 27, 2002
    Vancouver,B.C.,Canada
  2. PonchoJohn
    PonchoJohn Member
    96
    Jul 3, 2007
    Fresno, Ca
    This is coming from an observational point on, so take it for what it's worth, but the DSE unit appears thin and flimsy in the web picks. The ATS bracket is 1/4" thick. I agree that it's expensive (overpriced), but it is a GM designed piece that ATS bought the rights to. Maybe that's why it's expensive-- gotta pay back that purchase :)
    If you go w/ the ATS piece, do it soon- I don't know how much longer Tyler will be running ATS, as he is no in SoCal, working for Anvil Auto. It took me three weeks to get mine.
  3. Zedzag
    528
    Jan 27, 2002
    Good advice. I better pick up the better designed ATS piece quick.
  4. WMCC Doug
    WMCC Doug Veteran Member
    765
    Oct 16, 2002
    Wyoming, MI
    I used the ATS bracket. Worked well.
  5. woody80z28
    5,608
    85
    Sep 8, 2004
    walton, ny usa
    ATS here also. Expensive, but worth it.
  6. BLUE72CAMARO
    BLUE72CAMARO Veteran Member Lifetime Gold Member
    4,882
    270
    Mar 15, 2004
    Bunker Hill, IL
    ATS as well but expect it not to be a perfect fit. the angle of the dangle is wrong mine so I am going to have to either shim the clutch master on one side or pull my brakes and everything to bend the bracket some!
  7. Zedzag
    528
    Jan 27, 2002
    I'll make sure the angle of the dange is setup before I bolt up the booster.
  8. 130fe
    130fe Member
    50
    May 7, 2006
    Jacksonville, FL
    If you can wait a few days, I will have an extra one that I can give you a good deal on one. PM me for details.
  9. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    Chris,
    I will be second in line for the bracket you are pulling. I have a nice piece of 1/4 in plate waiting to become the bracket but I have, thus far, totally chickend out on my T56 swap. I am scared that I will never get it done!
    Thanks and if ZedZag speaks up/pays up first. . .I will fab mine out of this $4 piece of steel!
    Brent
  10. 130fe
    130fe Member
    50
    May 7, 2006
    Jacksonville, FL
    PM back to you Zedzag. Brent, I will keep you in mind.
