t-56 speedo/ reverse lock out question
Discussion in 'High Tech Retrofits' started by purpleflame, Apr 29, 2008.
  1. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
    #1= What is the best way to get my speedo to work, the t-56 has a speed sensor can I just put my gear off my saginaw on the t-56 shaft and run the old speedo cable.
    #2= What is the best way to run the reverse lockout just hook it to a toggle switch?
    Thanks for your advice,
    Purpleflamzz
  2. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    the VSS on the T56 is not gona run your cable speedo, Id just run a aftermarket digital speedo
    The reverse lockout can be removed completely & just make a block off plate. Or wire it to a toggle or wire it to the brake light switch
  3. BonzoHansen
    20,236
    1,512
    Jun 1, 2005
    Scott from Hamilton, NJ
    or get a cable-x and use your current speedo.
  4. woody80z28
    5,601
    77
    Sep 8, 2004
    walton, ny usa
    I've heard way too many people who were unhappy with the Cable-X. FWIW
  5. Todd80Z28
    11,850
    420
    Jun 11, 2002
    Northern VA
    I used an electronic speedo from VDO.
    I wired the reverse lockout to a rocker switch that's on the console, right by the stick. Sure you can take it out, but the T56 WILL go into reverse if you miss the shift from 4th to 5th.
  6. BonzoHansen
    20,236
    1,512
    Jun 1, 2005
    Good to know. I've only talked to 2 guys, who were both happy.
    I plan on electric speedo too. VDO, actually.
  7. woody80z28
    5,601
    77
    Sep 8, 2004
    walton, ny usa
    If you leave the solenoid in the trans and do not hook it up it makes selecting R tough. You just have to muscle it in. One of these days I might wire it into my brake lights, but then again I might not. It really works fine the way it is. No worries about shifting from 4 to R when banging gears.
  8. Todd80Z28
    11,850
    420
    Jun 11, 2002
    Northern VA
    It took me around 5 years to get around to hooking up the reverse lockout. You really have to push to get into reverse, but it was manageable. If you take the solenoid out, that spring pressure is lost. Since reverse is fully synchronized, unlike older transmissions, it generally will drop into R at 50mph from 4th, with just the slightest grind. I've done this once or twice when I've forgotten to turn the switch off.
  9. John Wright
    14,999
    321
    Aug 9, 2002
    Rustburg, Va
    I bet that could be quite the surprise when the clutch is released......
  10. woody80z28
    5,601
    77
    Sep 8, 2004
    walton, ny usa
    I hope his clutch slipped. haha
    That's why if I do it, I'll do it wired to the brake light switch.
