T Top Problems 1980 Z28
Discussion in 'Troubleshooting & Diagnosis' started by prats4, Dec 9, 2006.
  1. 8pack
    2,964
    313
    Aug 29, 2007
    Western, MA
    There is no one single bolt for the window adjustment. Search in here. There is a detailed thread somewhere on how to adjust your glass. It is slow tedious work.
    In case it wasn’t obvious, I should also clarify that to adjust the front and rear brackets on the opening you have to remove the trim covers.
    I forgot about the door adjustment alignment. Definitely get your gaps right and the door properly aligned before adjusting anything else.
    Glad I helped. There are A LOT of different adjustment points to get the tops to fit right and the windows to open and close properly. You also want the tops tight enough that the dont vibrate loose at highway speeds or rattle.
    Good luck!
    Francesco likes this.
  2. Francesco
    Francesco Veteran Member
    367
    44
    Jan 9, 2015
    Drummondville, Quebec
    Yes! I know that you have to remove the trim covers to adjust the screws for the brackets. Im learning all this as I fix it. Yes theres a sticky on the doors and 8 or 9 points of adjustment in the door. Looks like a hell of a job.
    8pack likes this.
  3. Francesco
    367
    44
    Jan 9, 2015
    Hi guys! Ive been playing around with my T-top for a few days and found out how not to make them leak without any extra material such as silicone and stuff. I found 3 adjustement points...The brackets on the center of the roof rail where you push the glass in, the chrome brackets at the top of the A and B pillars and the rods in inside the tops. To get a perfect seal, those 3 points have to be more or less adjusted but the most important adjustement is the pie wedges on both the primary and secondary seals. The secondary seal pie wedge has to really come on top of the primary wedge on the both ends and there has to be an even resistance when you latch the top on. When the seals are new, its a bit hard to latch in but it does and if the wedges come togheter well, then its impossible for water to get in. The other factors are of course the door glass and the correct gaping of the doors however those are indepedant of the weatherstripping fit. A good installation will never have leaking issues. It takes time to do a great job when your new at this stuff. The more i look at it and the more i understand how they work and let me tell you, GM did a good job when they built these T-tops. I got the real old school fisher body service manual for 79 and it also helped alot. When someone tells you that T-tops always leaked its false. Its either they never had one or they just dont want to service the problem and they keep leaking.
  4. 8pack
    2,964
    313
    Aug 29, 2007
    Western, MA
    Sometimes the answer is right there and you don’t even realize it….
    Glad you got them to fit properly.
  5. Francesco
    367
    44
    Jan 9, 2015
    Hey pal! Well...I figured out how it works now i need to adjust it so its on right. The A pillar squeeze is right on but the B squeeze is off and so i need to pull the secondary out more so that it can seat on the B pillar ball. Then when you latch it, both A and B wedges squeeze correctly. Thanks 8pack!
    8pack likes this.
  6. biker
    biker Veteran Member
    4,186
    2,070
    Dec 7, 2014
    Great job man. That is some tedious work! Nice to understand it though.
  7. 8pack
    2,964
    313
    Aug 29, 2007
    Western, MA
    As you drive it you may need to adjust it every few months. As you pointed out they can be leak free. I think the issue was no one made periodic adjustments and as the car flexed and the moulding aged thinks loosened up. I never did because I didn’t know better back then.
    Update the thread periodically especially after you get a hose and water on it!
  8. Francesco
    367
    44
    Jan 9, 2015
    A lot also has to do with the type of seal your using. Right now the ones i got are really hard! The rubber is hard around the doors and top. When you latch, you can feel that they are new. Next summer i would be prepared to get softer ones and start all over lol. I tried getting soffseal on the website but i cant. Maybe because im in Canada. By the way, what really causes the tops to rattle is the rod bolts under the plastic trim cover. The bolts on mine are blue (or are they all blue?) and you have 2 on each side. Mine were loosened up with time and i had no idea until i tried to unbolt them with the wrench. They had no torque at all! I was able to unbolt them with my fingers! Once i got them nice and bolted in, i took it for a spin on the crapiest street i could find near my domicile and there was no more rattling! That fisherbody book is sooo good!
  9. Francesco
    367
    44
    Jan 9, 2015
    So i adjusted my seals ok. Now the problem is coming from the latching. I noticed that the corner of the t-top panel comes over the side chrome trim along the B pillar. On the passenger side, the gap is ok. When I latch on the left side, the T-top will shift out on the B pillar. Its not the seals or brackets where you latch in. If the rods are not evenly lined up, can the t top shift out when you latch it? Im going to add pictures for this.
