VandykeT/A
I swapped a LS1/T56 set up in my 80. I bought the speed tech bracket and drilled a hole to keep the clutch master cylinder rod straight. The problem I’m having is the clutch pedal has very little travel. Should I drill another hole up to get more throw on the pedal. It’s basically like the pedal and master rod are working 1 to 1 now I’d like to have more pedal travel. I have clutch pedal stop made/ welded to the pedal itself and is adjustable but it’s not even touching the floor for testing. It’s all factory replacement hydraulics for a 4th Gen. The clutch is also kind of dragging. Has anybody else had this issue? Thanks
