Tail pipes--2.5 vs 3 inch
Discussion in 'High Performance Modifications' started by 76z28, Dec 9, 2020.
  1. muscl car
    23,097
    1,590
    Jul 8, 2001
    SoCal High Desert
    Your tail pipes are exactly how I ran mine when I was running 3" tail pipes , I copied how the first gets had them
  2. Lowend
    16,090
    1,079
    Mar 25, 1999
    San Jose, CA, USA
    I'll note - don't just run turndowns on the mufflers. Most are designed to have at least 12" of pipe coming out of them. Not to mention it gets very "throbby" inside the car.
    If I was doing this today, I'd be tempted to use run the pipes diagonally outbound and dump down-out near the sides of the car
  3. C4Racer
    C4Racer Veteran Member
    736
    149
    Oct 26, 2018
    Yup - I am running these and they go just under the axle.
    https://www.summitracing.com/parts/...vuUmzfr5LJhSQLLDpivTTNWmhUBk2FZhoCBzQQAvD_BwE
  4. BonzoHansen
    20,644
    1,745
    Jun 1, 2005
    Scott from Hamilton, NJ
    they kick up dirt off the pavement too.
  5. C4Racer
    736
    149
    Oct 26, 2018
    yes - they do indeed
  6. biker
    biker Veteran Member
    3,031
    1,280
    Dec 7, 2014
    I had that same kit from Torque Tech on a 502 in my 77. Awesome fit and install. They were in Valdosta Georgia.
  7. Jodi
    Jodi Veteran Member
    758
    452
    May 22, 2019
    not sure Fbird... could be, it's an old school build LOL.
  8. G72Zed
    G72Zed Veteran Member
    2,536
    1,156
    Sep 8, 2015
    I used my old cast off 90's "Mullet-Flowmaster" cases to start with, and a Flowmaster "U-Weld" it kit for 250$, 6 band clamps...some Tim Hortons and a chop saw & a MIG and I went to town. I have built another set of mufflers that worked real well, 40$ cases to start with.
    I got 381$ in it....but that's no labour.
  9. muscl car
    23,097
    1,590
    Jul 8, 2001
    SoCal High Desert
    3" true duals with Flowmaster Top 10 one chamber race mufflers
  10. ZenBoy
    ZenBoy New Member
    27
    May 8, 2001
    Minneapolis, MN
    For those of you that cut off the tailpipes before the bumper...have you had any issues with exhaust gas building up inside the car through the trunk and back seat?
    I had a Flowmaster 2.5” system cut off inside the rear axle hump for a “stealth” installation, and ran it that way for a few years. I always reeked of exhaust, and caught myself getting low on oxygen inside the car a few times. Finally I had tailpipes welded on to fix the problem.
    Nobody else has had that issue?
    75Maro and serpent710 like this.
