Taller slicks and RPM drop
Discussion in 'Competition Camaros' started by wwest, Feb 9, 2016.
  1. wwest
    wwest Veteran Member
    1,553
    Mar 29, 2000
    Chelmsford, MA
    Oh hell...Im at around 550...lol.
    Im going to take a good look at wheel well space and make sure Ive got all I can get in there.
  2. vegas1974z28
    4,661
    123
    Jan 10, 2002
    Las Vegas,NV
    I run the MT stiff walls as well......at about 650 FWHP 3400 race weight
  3. mrdragster1970
    7,821
    507
    Apr 12, 2007
    The 29 x 10 might be the one.
    Your car might not like the stiff sidewall???
    They also have a 29 x 9, that will give you more spacing.
    Plus as mentioned, there is drag radials, maybe they have a model that fits.
    I've never used one and none of my buddy's use them.
    Our local track is a crap hole, and my buddy's don't want to deal with them.
  4. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Did you use a stiff and regular on the same combo???
    If the 60' changed, that would tell if one is better or they're about the same??
  5. OldCamaroNut
    OldCamaroNut Veteran Member Gold Member
    948
    Apr 27, 2005
    Rancocas Woods, NJ
    Converter slip/lock up affects rpm's a bunch. What gears are you running? If you look at my sig line you'll see my setup, and my car would trap at 6300-6400 rpm.
  6. Bobalos
    Bobalos Veteran Member
    345
    Dec 6, 2005
    If you want to run a slick & are not sure about which type of sidewall to get, you can run it with a tube & then take it out if you want less sidewall. Now days, I think most folks are running the stiffer sidewall or putting tubes in them (giving you about the same). If it were me I would run the tube & make the car work with it.
    Bob
  7. wwest
    1,553
    Mar 29, 2000
    Chelmsford, MA
    Oh Im running tubes!
    This is the only tire Ive ever run to be honest. I don't go to the track enough to burn through them, so they last a while.
    Im thinking 29x9.....
    OldCamaroNut.....this is creepy.
    We are running the same car...lol
    Same motor, intake, 950 Prosystems, Marvs old AFR 210s, solid roller .630, SRP flat tops, stock crank, 1/34 headers, COAN converter (4500 stall), Garage built turbo 350, 4.11 gears. I think my extra tenth comes from me being 100 pounds lighter. That's CRAZY.
    What tires were you running? If you are running 30's, that could be where the RPM is....
  8. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I've seen weirder things happen, but with such a small engine and power I really don't see a 4500 converter being that inefficient???
    I have a 6900 stall with my 557" and I can see on the computer it's bad on the big end.
    I just don't care it's over 8000, it has good parts and the tunnel ram loves 8000 plus.
  9. wwest
    1,553
    Mar 29, 2000
    Chelmsford, MA
    OMG...lol
  10. Marv D
    10,851
    May 12, 1999
    Devils own training ground,,, aka Arizona
    YUP,, I KNEW RPM was going to be an issue eventually. LOL
    I totally agree Wade,, keeping RPM down is the wiser move, but how...?
    Taller tire yeah,, but I'm not so sure I'd go to a narrower tire to accomplish it. Your doing a good 60 now,, Just keep in mind "What happens in the first 100 feet of the track COMPOUNDS down track" If you start giving up 60 ft to get RPM down I'd believe your going the wrong way.
    One solution may be changing wheel offset and mini-tub to stuff as much tire as you can in there. That's always been my solution but then... I have been known to take the easy (not necessarily the cheapest) way out on occasion.
