Temperature Gauge Not Registering
Discussion in 'Electrical Systems' started by Kent LaBerge, May 23, 2020.
  1. fvdillon
    fvdillon Veteran Member Lifetime Gold Member
    919
    Jul 16, 2000
    Crete,IL
    Kent, did you ever get this resolved? I'am having the same problem, Thx Jim
  2. Kent LaBerge
    Kent LaBerge Member
    49
    Jul 18, 2011
    Mission, British Columbia
    No I have not yet solved the problem but have been testing. I ran the test of ground a wire from battery ground to sending unit and the gauge reacts as it should, which means the gauge and sending wire are okay. But at the same time I get an ohm reading on the sending unit. i am currently waiting for a new sending unit from my supplier (it's been awhile) and will try that first and should that not be the issues then I will pull the gauge out and test.
    I would have attached some notes I have made from various sources that made it easier to follow the test process but it has a file extension that this site will not accept. If u want to give me your email address let me know and will send it that way. ([email protected])
