Temperature Gauge Sending Unit/Switch for 74 Z28 Question
Discussion in '1974 Specific' started by 74Z28GC3, Mar 5, 2019.
  1. 74Z28GC3
    74Z28GC3 Veteran Member
    1,750
    65
    Sep 1, 2000
    North Pole, Alaska
    I plan on changing to the U14 gauge setup due to my 74 Z28 coming original with the idiot lights in it. Will my original type spaded temperature sending switch be correct to use when changing to an original temperature gauge?
    Thanks,
    George
  2. Green hornet
    Green hornet Veteran Member
    1,847
    375
    Oct 11, 2015
    North Bay, CA
    No the sender is different. Here is the one you need to work with the U14 temp gauge. It’s at O’rileys “BWD WT359”. I have posted this quite a few time for other member doing the swap. I had gotten the number from a member here when I did the Change over a few years ago.
    zfool likes this.
  3. 74Z28GC3
    1,750
    65
    Sep 1, 2000
    North Pole, Alaska
    Thanks Green Hornet. Our Fairbanks, AK Oriellys has one with a new number of TS76.
  4. djgriff
    djgriff Member
    78
    May 9, 2009
    van nuys , CA
    I have tried both those #s and my gauge reads a bit less then the actual temp with the BWD 359 being a bit closer, by the way I did not know that you could get a Z28 without factory gauges I always thought that the gauges were part of the z28 performance option?
  5. mallard
    mallard Veteran Member
    722
    165
    Oct 3, 2013
    SK, Canada
    In '74, believe it or not, you paid extra for gauges even with the z28 option. However gauges were included if you ordered the type LT option.
  6. Jeep43
    Jeep43 Veteran Member
    1,343
    53
    Mar 30, 1999
    Connecticut
    Anybody know of a sender for gauges that has a 3/8 NPT thread? The dart heads in my car have this and not the larger NPT in the factory heads. I tried TS66 for an 87 Camaro but the gauge doesn't register (the gauge does peg when I ground it).
  7. Green hornet
    1,847
    375
    Oct 11, 2015
    North Bay, CA
    The one I listed in post #2 is a 3/8 pipe thread.
  8. zfool
    zfool Veteran Member
    610
    23
    May 19, 2014
    Rochester, MN
