Testing a dwelle meter
Allison Winn
436
I always thought it odd that the old school dwelle meter I have, has a small handwritten note on the front that says "zero the needle then 24 1/2 degrees equals 30 degrees".
The zero the needle I understand but is a dwelle meter capable of measuring incorrectly? Or maybe previous owner used to on a 6 cyl and had to mentally convert the reading? I wonder how to validate a meter reading - my car seems to run the same when points are set to 30 or 24 1/2.
tom3
14,674
ohio
Might get new points, set them as exact as you can with the feeler gauge, then try the dwell and see what it reads. I wonder if they had a dual point setup? Not sure how that would read or if it could be used. Dwell affects ignition timing too so check that after any points adjustment.
Allison Winn
436
Here is a pic - the small black screw zeros the needle
