Th-350 leaking out of the speedometer gear housing
Discussion in 'Transmission & Driveline Topics' started by TDPalmer, Mar 26, 2017.
  1. TDPalmer
    TDPalmer Veteran Member Lifetime Gold Member
    823
    Apr 25, 2011
    Cave City, Arkansas
    I've been having this issue where I'm having transmission fluid leak out of my speedometer housing, it seems to leak worse right after I get done driving it. It will leak maybe a pint out over a couple of weeks and leave a huge puddle underneath it. I have replaced the seals once with the Classic Transmission Solution Stop Leak Kit, and a new speedometer gear. After I emailed them saying it didn't work the first time they sent me another kit free to put in it plus another a free gear. I installed them this weekend and I will keep looking to see if that fixes my problem.
    When I take the cable off the housing no fluid comes out of the cable or it's sleeve and it doesn't come running out of the housing hole when I take the housing out.
    Is there anything else to look at to stop the leak? I am pretty confident the transmission is not leaking from anywhere else I have crawled all over it looking for another leak, the pan seal is dry, and the rear housing is dry.
  2. COPO
    21,046
    2,582
    GM still sells the bullit or you can just buy the O ring.
    In my case, I just bought a new O ring and used Permatex 2
    just on the outside area of the O ring to seal any possible leaks from the case.
    I have no leaks.
  3. 496z28
    496z28 Veteran Member Lifetime Gold Member
    967
    8
    Sep 23, 2007
    Oklahoma City
    I second putting permatex on it. 515 is some amazing stuff. Lol
  4. brooksman9
    brooksman9 Veteran Member
    6,309
    307
    Jun 10, 2007
    Olive Branch, MS
    The Right Stuff is good too.
  5. TDPalmer
    823
    Apr 25, 2011
    Cave City, Arkansas
    Thanks for all the reply guys. I put permatex on it today after it started leaking from the new seals. If this don't work I'm gonna buy a new bullet with the seals already installed and go from there.
  6. Coadster32
    2,300
    366
    Oct 2, 2013
    Milford,CT
    You're on the right track. Mine was the small O-ring. My housing had permatex on the outside by the bullet. No leaks.
  7. COPO
    21,046
    2,582
    I don't see how the bullet would wear. Maybe the O ring is not the correct one and has slop.
