TH350 RPM Drop when put in gear
Discussion in 'Transmission & Driveline Topics' started by BP80Z28, Jul 6, 2017.
  1. BP80Z28
    BP80Z28 Veteran Member Lifetime Gold Member
    1,153
    Sep 2, 2008
    Plymouth Mass
    Hi th350 when put in gear the rpm's drop to almost stall. What should I be looking for.
    Thanks
  2. budro6968
    budro6968 Veteran Member
    3,918
    747
    Apr 2, 2016
    Jax Florida
    Check timing and raise curb idle to spec. Set parking brake and chock wheels first.
    BP80Z28 likes this.
  3. cadillac_al
    cadillac_al Veteran Member
    984
    130
    Apr 22, 2015
    Maine
    In my experience it is usually a big vacuum leak. It should slide into gear with very little idle drop.
  4. CorkyE
    11,313
    877
    With a stock torque converter, you'll have a bit of a drop, but not like you're describing. Those are two good posts above, I would start first looking for a vacuum leak. If you have a leak, you'll never get the carburetor adjusted. I like to use an unlit propane torch to check for vacuum leaks, there are other methods. After leak test/repair, verify the timing is correct, then move to adjusting the carburetor.
  5. budro6968
    3,918
    747
    Apr 2, 2016
    Jax Florida
    My buddy was trying to do the curb idle on his ford F100, He was inside the engine bay to adjust. He blipped the throttle and ran the truck into the wall with him in the bay. His wife could not wait to tell me that one. This is a guy I have known for years
  6. 70-camaro
    70-camaro Veteran Member
    3,411
    1,809
    Mar 25, 2010
    marietta ohio
    Are you running vacuum advance? If so ported or manifold vacuum? When I tried to run full manifold vacuum mine would not idle in gear either. Switched to ported and no problems.
    Kricka likes this.
