TH400 ATF question
Discussion in 'Transmission & Driveline Topics' started by SOD, Jul 3, 2014.
  1. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    Dexron 3 works for anything calling for dextron 2 or 3.
    Trickshift is not all that it's made out to be. It's pretty much just type F and dexron mixed together
  2. Twisted_Metal
    28,306
    1,693
    It will be a funny color with red and blue mixed together but that won't matter.
    Some people use clear hydraulic fluid in their transmissions. Just makes it harder to tell what fluid is leaking.
    I don't recommend using hydraulic fluid if the proper automatic transmission fluid is available.
  3. SOD
    SOD Veteran Member
    126
    May 16, 2011
    Russia, Saint-Petersburg
    Thanks for help guys.
  4. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    a friend used to work for the local Mobil Oil refinery. They had the contract to manufacture Trick Shift (a number of years ago). He asked the engineers about the product and they told him not to use it in his car. Mobil got the contract because they were the low bidder and they were the low bidder because they barely met the minimum specs for the product. Use a good brand of Dexron and you'll be fine. Good luck.
  5. SOD
    SOD Veteran Member
    126
    May 16, 2011
    What European brand you can recommend?
  6. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    GM/Opel sells cars in Europe, check out what's available for those automatic trannys. I'd imagine they have to be the same.
