Th400 cooler line flare size
Discussion in 'Transmission & Driveline Topics' started by CamaroMan79, Aug 31, 2017.
  1. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,206
    19
    Jun 10, 2001
    Selah, WA
    Does anyone know what size the flared fitting is on the end of the cooler line that connects to the radiator?
  2. steins70z28
    steins70z28 Veteran Member
    301
    48
    Apr 14, 2012
    Tulsa, OK
    Mine on my 70 with th400 are 1/2" on the radiator.
  3. CamaroMan79
    5,206
    19
    Jun 10, 2001
    Selah, WA
    My radiator uses AN fittings so I want to screw an AN coupler fitting to the ends of the hardlines and then run hose to the fittings on the radiator. I'm guessing I need this fitting then.....https://www.summitracing.com/parts/rus-640600/overview/
  4. steins70z28
    301
    48
    Apr 14, 2012
    Tulsa, OK
    Seems right the hard line
    fitting is 1/2 -20.
  5. 77 cruiser
    77 cruiser Veteran Member
    582
    35
    Nov 17, 2006
    Frostbite Falls MN
    5/16 inverted flare
