TH400 from truck fit?
Discussion in 'Transmission & Driveline Topics' started by reinhardt79, Feb 19, 2016.
  1. reinhardt79
    reinhardt79 Veteran Member
    858
    May 12, 2002
    VA BCH, VA
    Found a th400 in a 1988 2wd crew cab dually. Will it fit in my 79 Camaro? Is it a good choice for drag racing behind a 454? Going low buck, fun weekend toy. Thanks all.
  2. CamaroGP
    CamaroGP Veteran Member
    691
    90
    Nov 10, 2012
    Summerfield, Florida
    TH400 trans will work for drag use. Being a 1-ton truck. It probably has the factory HD sprag. The dually will have a three piece drive shaft and a bolt in yoke in the trans. I believe a slip yoke (std for car one piece shaft) will work fine. TH400 mounts in a different location than the TH350 so an aftermarket or modified crossmember is in order. the TH400 yoke is different also. TH400 is longer than TH350 so different driveshaft length is required. Don't let all this scare you away, it is a fairly common swap. Plenty of information here if you snoop around.
    P.S. I have a TH400 behind a 454 in my car. Works very well.
  3. Coadster32
    2,024
    260
    Oct 2, 2013
    Milford,CT
    I have a TH400 behind my 383 without issue. Stout tranny. Most say the stock crossmember, (or from TH350), can be shifted back one hole, and drill another set thru the frame for reuse on the TH400. Good luck.
  4. Fbird
    4,910
    1,094
    Feb 12, 2011
    atlanta, ga
    yup. easy peezy. the crossmember is the only thing that gets a little ...fuzzy. Many ways to mod that.
  5. reinhardt79
    858
    May 12, 2002
    VA BCH, VA
    I'm not afraid of fab work. Machinist work makes me nervous though. Are you saying the driveshaft bolts to the output shaft of the tranny on the truck? If so, how do I make that work with the Camaro?
  6. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    3,368
    194
    Aug 5, 2007
    Various barns in N. IL looking for chit.
    Have the same 454/TH400 setup in my 72. Just cut off the mount of the 350 crossmember and put it on the backside. Done.
  7. CamaroGP
    691
    90
    Nov 10, 2012
    You will not have to machine anything. You will need a yoke from a car or van, light truck. Something that has a slip yoke. The dually output shaft will be threaded in the end so the truck yoke can be secured in place. If you use a bolt in yoke in an application that requires a slip yoke you will have a large hole behind the u-joint. A bolt in yoke will have straps holding the u-joint caps on just like on the rear dif. A standard slip yoke should work in a bolt in yoke transmission.
  8. Bikefixr
    Bikefixr Veteran Member Lifetime Gold Member
    1,826
    97
    Mar 13, 2006
    TH400's come with short tailshafts and long tailshafts. You need the short tail for a Camaro. Proper driveshafts are easy to find. The TH400 was stock behind the 70-72 Big Block cars.
  9. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    The tailshaft is the big question mark for fit. B body(Impalas, Pontiac Bonnevilles) had a long tail shaft. can get a short tailshaft and output shaft to convrt.
  10. krabben1
    8,222
    64
    May 16, 2007
    ( . Y . )Delco
    I have the exact same trans you have.From an 88 dually.
    I was told to use it,I'd have to get a special yoke,that is longer to engage right,or buy a new output shaft.
