TH400 Swap
Discussion in 'Transmission & Driveline Topics' started by 1980 Camaro Berlinetta, Feb 25, 2011.
  1. 1980 Camaro Berlinetta
    1980 Camaro Berlinetta Veteran Member
    2,365
    Dec 12, 2000
    Fairmount,Indiana
    Getting ready to put a TCI tranny in & was wondering about the driveshaft. Does it need to be shortened? I know I need a different yoke. Also do I need to change the cross member? Any info would be appreciated!
  2. Fbird
    5,885
    1,740
    Feb 12, 2011
    atlanta, ga
    yes and yes. Driveshaft needs 3/4" taken out (shorter) that is if you are going from a th350 short tail (or 4 speed) to a 400 short tail. the xmember is a little bit different. 2 ways to do this. Depends on YOUR garage. 1. buy a 400 x-member---$150 ish. 2. Take yours and CUT the mount off (the little "shelf") and weld it onto the rear of the x-member. works out the 3.25" difference. Either way should net a x-member that bolts to the frame in its original location, hieght ...blah, blah...
  3. Fbird
    5,885
    1,740
    Feb 12, 2011
    atlanta, ga
  4. 1980 Camaro Berlinetta
    2,365
    Dec 12, 2000
    Fairmount,Indiana
    Thanks! At least this gets me started in the right direction.
  5. crystalbluevib
    crystalbluevib Veteran Member
    202
    Jan 2, 2011
    IL
    you could get a 400 cross member for alot cheaper than $ 150.00. Less hp to turn.
  6. Ryan 79
    Ryan 79 Veteran Member Lifetime Gold Member
    3,299
    Mar 29, 1999
    Granite Falls, WA
    Try the shaft before you have yours cut.
    When I put the 400 in my 79, I was planning on having it cut as well, but I didn't need to.
