The Beast gets rewired finally
Discussion in 'Project Progress' started by Aceshigh, Aug 22, 2009.
  1. 79camaro2001
    4,773
    May 4, 2003
    Monroeville, PA
    That Nascar connector sure does look interesting!
    A little over kill, but I'm still not sure on how you are wiring it up, plus you got all of the FI wires to deal with so it might be a good thing.
    Where you get that by the way?
  2. 79camaro2001
    4,773
    May 4, 2003
    Monroeville, PA
    Is that a actual connector or just a place to pass through your wires??
    Maybe a description of that bulk head connector would help, just trying to learn about it!
  3. KJZ28
    KJZ28 Veteran Member Lifetime Gold Member
    3,134
    Sep 26, 2004
    Brewsterico, New Fail
    That air cleaner looks a little........beat? Everything else is coming out great!
  4. Fleetwiz
    Fleetwiz RIP 3/11/18 Lifetime Gold Member
    427
    Apr 26, 2003
    Vernon NJ USA
    Looking Ace...keep us posted...
  5. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    http://www.amazon.com/Delphi-Packar..._1?ie=UTF8&s=automotive&qid=1251685982&sr=1-1
    22 port Bulk Head connector. 10 ports for 12 gauge, and 12 ports for 14-18 gauge.
    I got this, plus the AAW Hwy 22 kit from Muscle Rodz who is a vendor here.
    Obviously cheaper.....
    I am doing this instead of just running large lengths of wire through a rubber
    boot thru my firewall. This gives me a simpler disconnect point if I need it later
    or I can ADD on to it later also.
    I fell on it Saturday....lol
    I was laying across the engine TRYING to unbolt the brake booster from all
    these very awkward angles, and then I squished it on accident. Finally I
    gave up and removed the hood.....which I should have just done from the get go.
  6. 79camaro2001
    4,773
    May 4, 2003
    Monroeville, PA
    Got ya, not a bad deal, I'll have to remember that when it's time and see if that's something I want to do.
    Also doesn't that suck when you try to cut corners and you end up breaking more? LOL
  7. amargari
    amargari Veteran Member
    1,241
    18
    Feb 19, 2003
    Morristown, NJ, USA
    Looks good. I didn't have room putting mine there with the clutch pedal. I put mine up under the dash on a bracket I made and welded to a dash support.
    Here is the bracket welded up:
    Here is the fuse box mounted:
    I also put my bulkhead in the fenderwell.
    I am in the process of wiring everything now. I have finished group A and most of sheet B. So far I am very happy with the kit.
  8. KJZ28
    3,134
    Sep 26, 2004
    LOL!! Thats a funny image.
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    You know, I wish I had a welder.....
    Because I reallly like where you put yours better.
    It's COMPLETELY up and out of the way.
    This is where the stock fuse panel went, so it works, but if I didn't
    have the ECM for the LS1 I would have put it behind the glove box.
    As for the bulkhead connector......how are you running your wires to it ??
    Through the kickpanel ??? How's that going to work out ??
  10. amargari
    1,241
    18
    Feb 19, 2003
    Morristown, NJ, USA
    Thanks. It took me a long time to decide where to put the fuse box.
    I am going to run the wires through the large hole behind the kick panel. I may have to look into a way to protect them from water.
