The low car scrapings dilemma!
TIP-T0P
82
Contra Costa County
Just bought the car, got it home yesterday. I have a steep garage driveway incline, my new '71 Camaro's header to pipes thick flange is hitting just before car levels off into garage. šŸ¤¬ my son helped me by putting wood just before rear tires to give it lift I needed. I might need to build wooden ramps every time I move the car. Having a Crest to go over and center bottom your car is a harder problem to figure out than a curb to driveway problem.šŸ¤” I only found one photo of a guy who built a wooden ramp, (photo attached), any other suggestions welcome!
biker
5,309
Have u rotated the flanges on the headers so a flat is exposed to the road surface instead of a bolt hole? I know its not much, but every little bit helps.
djorgensen3
961
Peoria, Az
Have the bolt flange changed out to a slip fit with tabs and a spring on each side or two overlapping tabs with a bolt that runs vertical with one on each side.
TIP-T0P
82
Contra Costa County
My exhaust system is quite extensive, hate to have to have it modified and lose cutouts etc. But those BB headers hook up lower than I would like.
TIP-T0P
82
Contra Costa County
Considering different types of rubber humps also may be a solution, but I need more than 2-3 inch lift and one with length to drive on, not just a short speed bump hump.
