The perfect 2nd gen Camaro alignment specs
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ULTM8Z, Jun 7, 2014.
  1. ULTM8Z
    ULTM8Z Veteran Member
    10,229
    964
    May 19, 2000
    Los Angeles
    Just got back from the alignment shop.... Couple of weeks I had replaced the upper and lower ball joints and put in the Moog offset control arm shafts (flipped around).
    Holy smokes, it's a totally different car now! :eek:
    .5° neg camber
    2.5° pos caster
    .25" total toe in
    Together with the AGR steering box (which I've had for a while)... Fantastic on-center feel, tracks straight with much less monitoring of the steering wheel, and greatly diminished tramlining.
    I went in asking for the Guldstrand touring specs. Didn't quite get as much caster as the spec (I understand it's difficult with factory upper a-arms), but I'm VERY happy with this car now. :cool:
    I'll drive it around like this for a while and then install the Y-braces for a good A to B comparison. The car feels great now, but If folks are saying the Y-braces are even more of an improvement... Can't wait to see! :)
  2. woody80z28
    5,633
    121
    Sep 8, 2004
    walton, ny usa
    Wow, that seems like a lot of toe.
    When I swapped the IROC box in mine I noticed a huge difference, way more than the Y-braces made...
  3. ULTM8Z
    10,229
    964
    May 19, 2000
    Los Angeles
    The Guldstrand specs said 1/8". I assumed that was per side. Is it 1/8 total?
    If 1/8 is supposed to be total, I could probably let a little out on my own.
  4. woody80z28
    5,633
    121
    Sep 8, 2004
    walton, ny usa
    I could be wrong, but I was pretty sure that's total. I run 1/16 total on both my cars.
  5. m pozzi
    m pozzi Moderator Staff Member
    2,544
    Apr 9, 2002
    Central California, USA
    Definitely that value is TOTAL toe. And -1/8" is a lot of toe ... fix this quick or the outer tire tread shoulder will be mad. Shoot for closer to 1/16" toe-in total maximum.
    And yes ... OEM upper control arms suck for added caster.
    Mary Pozzi
  6. ULTM8Z
    10,229
    964
    May 19, 2000
    Los Angeles
    Understood. Thanks Mary!
  7. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    I've always run 1/16 toe in also.
  8. ULTM8Z
    10,229
    964
    May 19, 2000
    Los Angeles
    Just reduced to 1/16 total. Thanks.
  9. ks71z28
    ks71z28 Veteran Member Lifetime Gold Member
    2,150
    53
    Oct 10, 2004
    chico, ca, usa
    Yes 1/16" toe in- total!
    We really don't think that camber settings are as big a deal as most people thing. Likely you won't put 40,000 miles on your tires like your daily driver. I would bump the camber to 1* neg, and see if you can get more caster in the car. I will tell you that putting on a set of "good" aftermarket upper arms will allow you to get the 5* of caster you need for improved steering feel and feedback. People really don't understand the benefits of swapping in a performance steering box and upper control arms. Steering feel is one of the biggest upgrades you can do to improve these cars, and is often overlooked
  10. ULTM8Z
    10,229
    964
    May 19, 2000
    Los Angeles
    I could try sticking another shim in the rear control arm bolt and see if that improves things.
