The unbeatable locking lug nuts.
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by joel.hunter, Nov 25, 2015.
  1. joel.hunter
    joel.hunter Veteran Member
    296
    Nov 18, 2015
    Nanaimo, BC, Canada
    When I recently bought my '81, the owner mentioned that he didn't receive the key for the lug nuts when he bought it. In the year or so that he owned it, despite swapping and subsequently removing and installing the entire drive train several times, he never decided to remove the wheels. Unfortunately for me, I need to. The brakes are poo, pardon my language. And I need new rear tires anyways (I wonder why...). The problem is, these damned McGard locking lug nuts have a spinning sleeve on the outside, so you can't use and traditional tools or methods to get them off. Trust me. I've tried. Drilling them from the side is not an option, as there's no clearance. Drilling from the top apparently doesn't get you anywhere. The patterns are semi unique, so I can't just borrow or buy a key. McGard is stubborn and requires "verification" (apparently you get an id card when you buy the nuts) that they're mine and won't send me the key. I don't have a welder. Anyone know how to get these things off? I'd like to avoid going to a shop, because I don't think they can do it and they'll charge stupid money that I (a student) don't have.
    Any tips?
  2. Shizzle
    Shizzle Veteran Member
    2,801
    777
    Aug 1, 2012
    oak lawn, illinois
    I had no problems getting a key from McGard when I had the key break. Maybe tell them that. When I was one the phone with customer service, she told me there is only 4 patterns they use for the lock.
    Post a picture of the pattern as I have an extra key if it matches.
  3. midascircle
    midascircle Member
    33
    Dec 7, 2013
    saskatoon, saskatchewan
    there are various kits out there to remove them. Barring that you could just beat a socket on it and that sometimes works as well
  4. z28dug
    z28dug Veteran Member
    531
    Apr 30, 2004
    Baltimore, MD USA
    I've never had to do this but have heard you can hammer on the correct size socket to destroy the spinning collar than use one of lock removal sockets.
    I have also heard that there are a limited number of key combinations and some tire shops will have a complete set of keys.
    First choice would be to call the McGard about a replacement key.
  5. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,894
    606
    Aug 11, 2010
    erie, PA
  6. gordonquixote
    3,022
    11
    Jul 18, 2006
    Tallahassee, FL
    ^I think the outer sleeve spins on OP's security nuts.
  7. z28dug
    531
    Apr 30, 2004
    Baltimore, MD USA
    Exactly. I have the complete set of those sockets from Craftsman. They work great but with the case of the spinning collar you first need to defeat the collar. BFH and the correct size socket is supposed to take care of that.
  8. BonzoHansen
    20,811
    1,835
    Jun 1, 2005
    Scott from Hamilton, NJ
    how much access to the lugs do you have? Some wheels hide the lug nuts more than others. In last ditch effort I have used an air chisel to remove them, but you need room
    I hate lock lugs. They only stop car owners.
  9. harbone66
    3,498
    287
    Feb 15, 2011
    Central Illinois
    use a air chisel to remove or jamb up the spinning collar then take it off with a wheel lock removal socket
  10. joel.hunter
    296
    Nov 18, 2015
    Nanaimo, BC, Canada
    I'll try the air chisel, but I don't know if I'll have enough room. Four patterns? I've heard anywhere from that to thousands of patterns. Weird.
