This may seem strange
FNFAL308
174
Montgomery, TX
Bought a used 79 z28 limited slip rearend and replaced axle bearings, checked for bearing movement at pinion. Looked at clutch pack with s spring without removing. Put it in a backed the car up.
Backing up straight it was popping about every foot or two. First thought was the clutches.
Now thinking back on it the s spring was pushing against the clutches directly definitely not the spiders. Never saw that before but assumed it was ok. Haven't had a 8.5 limited slip since around 1985 so my memory is old.
Does the sound right? Taking it apart tomorrow likely. Any thoughts ? Is there a s spring style that the s spring pushes against the clutch pack and not spiders?
tom3
14,520
ohio
Should be like this:
FNFAL308
174
Montgomery, TX
I am likely wrong thinking back and looking at that extremely clean setup. The c-clips had to have a recess to fit into. I'll blame it on heat exhaustion.
But, when I drove it backwards a few feet (mostly straight slight slight curve) it popped making the whole car shudder. And then popped about every foot or two. Did not pop going forward under power driving down the street, but would pop if idling forward. Would wore out clutches do that? I've never had a set that was wore out. I figured that they would slip more not pop.
Drove down the street relatively normal, with a slight pop going around curve.
Not as bad after driving around neighborhood for 10 minutes but still bad. Used the oil that already had limited slip additive in it.
Could previous owner have shimmed it to tight?
Thanks for comments
FNFAL308
174
Montgomery, TX
Just checked with torque wrench, in neutral, one tire on ground, it breaks loose at about 50 ft/lbs. So a new clutch pack is going in regardless
CorkyE
11,737
Was a guy here that sold clutch packs for out 10 bolt rear ends. Haven't seen him around lately, but some searching might find him.
31,224
This thread mentions the clutch packs for sale.
ob355
66
Did you put in the correct additive? If so then i would check for missing/chipped teeth. the posi only works when you turn and one tire spins faster then the other. Are your tires the same size? U-joints healthy, and the pinon is not moving around?
