franks70camaro
wanted every ones opinion on this cam it going in a 383 stroker i have flat top 4 valve relief pistons 64 cc heads 210 runners and an rpm air gap intake headers n a th400 tranny 2400 stall
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .489/.504
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Includes: Cam & Lifters (#71817PR-16)
how well will this cam perform on the street n will it make this motor set up run awsome ?
LSA/ICL: 110/106
