Throttle pedal assembly
Discussion in 'Camaro Questions' started by AMPZ28, Apr 27, 2020.
  1. AMPZ28
    AMPZ28 Member
    40
    Dec 10, 2015
    Oshkosh,Wisconsin--USA
    Hello, im reassembling the throttle pedal and im not sure what the large metal bracket holds in the rectangular cut out. looks like a switch of some kind. Also, i installed a Detroit speed master cylinder and need a references for brake pedal height. currently the brake pedal is 11.5 inches away from the firewall(too high). Measurement of the factory brake and clutch distance would be appreciated.
  2. twestrup
    twestrup Veteran Member Lifetime Gold Member
    221
    115
    Aug 22, 2018
    St. George, Utah
    I know on a 70 Z-28, that bracket holds the switch for the Turbo 400 kickdown.
  3. AMPZ28
    AMPZ28 Member
    40
    Dec 10, 2015
    Okay, so with a 5 speed manual setup there's nothing to install there then. that clears things up. thank you
