tilt steering wheel swap
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by arnies81camaro, Apr 27, 2016.
  1. arnies81camaro
    arnies81camaro Member
    59
    Aug 20, 2011
    groveland,ma.
    does anyone know if a tilt wheel column from a 79 camaro will fit in a 70 camaro?
  2. J. Chris Davis
    J. Chris Davis Veteran Member
    840
    42
    Jul 13, 2004
    Dixon, IL USA
    Don't quote me, but I would think so. Don't think there was any difference there from 70-81.
  3. Mike N
    2,834
    576
    Jan 13, 2002
    Spencerport, NY.
    Look at the end of the column where the intermediate shaft hooks to, iirc early cars were splined and later were D shaped.
  4. dsbratton
    dsbratton Veteran Member Lifetime Gold Member
    404
    Oct 6, 2010
    Rochester, MN
    Isn't the electrical plug different?
  5. 71RS/SS396
    71RS/SS396 Veteran Member
    2,639
    41
    Aug 26, 2008
    Wake Forest NC
    I put a 79 column in my 70. Mike N is correct the 79 has a double D intermediate shaft and the 70 uses a splined shaft. There are also some differences in the wiring on the plug but, you can moves the pin locations to correct that.
  6. arnies81camaro
    59
    Aug 20, 2011
    groveland,ma.
    so did you have to change the lower shaft also?
  7. 71RS/SS396
    2,639
    41
    Aug 26, 2008
    Wake Forest NC
    I have a DSE subframe so I had to change the shaft anyways, I used the Borgesen u- joints and shaft. You'll have to change the intermediate shaft and re-pin the connector to use the 79 column.
  8. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,797
    103
    Aug 18, 2003
    On Wisconsin!
    yes
