timing issues
Discussion in 'High Performance Modifications' started by vegas1974z28, Oct 1, 2008.
  1. vegas1974z28
    4,674
    129
    Jan 10, 2002
    Las Vegas,NV
    Anyone know why I can set my timing at 36 total, have the dizzy snug, do the final tightening and the timing jumps 4 degrees...as soon as I tighten it no matter where the timing goes up. New distributor(MSD).
  2. camaronut79
    camaronut79 Veteran Member
    1,149
    Nov 11, 2005
    destin area, fl
    is the dizzy locked out?
  3. vegas1974z28
    4,674
    129
    Jan 10, 2002
    Las Vegas,NV
    no, In the 110+ heat I'm a little weary of locking it out, hate to be in elims and have it to hot to start.......I know I could and probably will get a better box to retard the timing.....but what the heck, it took us 5 times to finally settle in at 34 degrees
  4. jimbaughan
    jimbaughan Veteran Member
    310
    Sep 1, 2007
    meansville,ga
    This is just an idea, but your dist may be bottoming on the oil pump drive so when you tighten the dist down it causes the gear to climb changing the timing.
  5. vegas1974z28
    4,674
    129
    Jan 10, 2002
    Las Vegas,NV
    Believe it or not that was a thought also....
  6. Maliboost
    Maliboost Veteran Member Lifetime Gold Member
    7,185
    May 18, 2001
    X2.
    what happens if you set it to 38 & then tighten it down???
    Bob
  7. Damon
    Damon Veteran Member
    12,939
    24
    Nov 16, 2000
    Philly area
    Agreed with above. Put 2 gaskets under the distributor instead of 1 and try again. See if it's any different.
  8. vegas1974z28
    4,674
    129
    Jan 10, 2002
    Las Vegas,NV
    it goes to like 42
    I'll add another gasket today at the track and give it a whirl.....you guys are awesome.
  9. rscamaro73
    rscamaro73 Administrator Staff Member
    14,977
    17
    May 30, 1999
    Striking fear and destroying the enemy
    Just send us some checks....that's all :cool:
  10. vegas1974z28
    4,674
    129
    Jan 10, 2002
    Las Vegas,NV
    you got it brother...this is the real silicone valley
