Timing mark positions
Discussion in 'Engine Topic' started by Layne02, Sep 1, 2019.
  1. Layne02
    Layne02 Veteran Member
    139
    Jun 25, 2013
    Georgia
    I am wondering about timing mark positions on sbc’s. I have always seen them at the 2 o clock position for the most part, but I have an 87 305 that has it at 12 o clock, and an early 80’s 350 that has it at 12 o clock. My question is when did this change go from 2 o clock to 12 o clock. Thanks
  2. Twisted_Metal
    30,052
    2,778
  3. Layne02
    139
    Jun 25, 2013
    Georgia
    Ok cool , thanks. I did a search but didnt come across this one.
  4. GoldenOne7710
    5,592
    875
    Jun 23, 2004
    Athens, GA
    If you use an aftermarket balancer and timing tab, you can always use a piston stop to check the accuracy if the engine is already assembled and in the car. If it's off, you can use timing tape on the balancer to correct any variance.
    I'm running both an adjustable timing marker and aftermarket balancer. Mine was spot-on when it was installed, but I ended up using timing tape anyway since it's a lot easier to read when setting the timing.
