tire height difference
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by LoweRider, Jun 17, 2019.
  1. LoweRider
    LoweRider Veteran Member
    120
    32
    Jun 26, 2017
    TX, USA
    I'm looking to run MT's 305/45/17 in the rear when I buy wheels/tires for my camaro, but I want decent tires in the front, like Michelin's Pilot Sport 4S 225/50/17, but they're 25.9" tall and the 305s are 27.8" tall
    I want to avoid having a rake effect, and I dont want to try and find a 28" wheel up front that might affect clearance while steering. Would I have a noticeable forward lean with 1.9" tire height difference, or should I go with a 315/35/17 in the back to have equal tire heights?
  2. LoweRider
    120
    32
    Jun 26, 2017
    TX, USA
    no one?
  3. dcozzi
    dcozzi Veteran Member
    4,328
    1,324
    May 1, 2002
    Phoenix, AZ
    Check this out.
    https://bozeforged.com/downloads/17-Tire-Dim-Boze-041911.pdf
    I do not know if the rear will create a "rake" effect.
    2" will make the car 1" higher in the rear so, it may not be too bad.
    Maybe use a 1" block in the rear? I cannot remember if the stock perch is above or below the axle. I used an aluminum 1" block on my car but it had a 9" with the leafs attached under the axle so it lowered the car.
  4. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    914
    157
    Aug 14, 2008
    Texas
    As Dcozzi pointed out, the 1.9" you specified, is overall height difference, meaning 1/2 of that will occur below the centerline and 1/2 will be above. The increase above the centerline will not affect the ride height, but may have other clearance issues. - Also, the tires "give" a little at the bottom as well, so you may not experience the full inch of height.
    Also, I have no idea what is available, but if you could go with a 55 series instead of the 50, ( 225/55/17 ) that would buy you some height in the front, but again, may lead to clearance issues.
    If I recall, I believe Summit Racing sells quite a few tires these days and their website gives all sorts of specs on tire heights, etc. - May be a good place to start.
    hubedobeedo likes this.
  5. Fbird
    5,936
    1,769
    Feb 12, 2011
    atlanta, ga
    move on.......if your are THAT OCD about how level the vehicle is.... nothing metioned here is going to desuade that....get the tires...roll on .....look good !
    LoweRider and hubedobeedo like this.
  6. Peck
    Peck Veteran Member
    734
    255
    Mar 20, 2018
    Tacoma,WA
    Remember to keep your gear ratio in mind when discussing changing tire heights, the change may not bother you but you will notice it.
  7. hubedobeedo
    hubedobeedo 3rd times a charm
    761
    291
    Jul 18, 2013
    Huntertown,IN
    i does depend on how it sits now if it is level with current combo(are they all the same height) then there would be a small difference, but like mentioned above might not be that noticeable
  8. LoweRider
    120
    32
    Jun 26, 2017
    TX, USA
    appreciate the input, guys. I'll go with my original plan.
    I'm pretty much building my car from scratch right now. It's currently getting paint and body work. When that's done, I'm having the Quadralink I have sitting in the garage installed along with a 9" in the rear with 3.50 gears. Also doing a 4L80E behind a bbc.
