Tire size for 81Z?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Kae450, Dec 21, 2019.
  1. Kae450
    Kae450 Member
    66
    14
    Feb 5, 2018
    anyone have experience putting on wider tires on the stock steel rims? I’d like to do it but don’t want any wheel rub etc so can’t go too much larger than stock tire size I’d assume. Thanks
  2. Z28SSRS
    Z28SSRS Veteran Member
    181
    21
    May 2, 2009
    Nevada City, CA
    For about 15 years I ran 245/60/15's all around on the stock steel rims on my 78 Z28. They only rubbed in front at full lock on the inner fender liners. You couldn't feel them rubbing, only see the bare steel on the inner fender liners from where the tires rubbed. I currently run 235/60/15's all around with no rubbing anywhere, and my car handles much better with them than with the 245's. The stock tire size was 225/70/15. Hope this helps.
  3. Kae450
    Kae450 Member
    66
    14
    Feb 5, 2018
    Thanks it does
  4. La.Z8
    La.Z8 Veteran Member Lifetime Gold Member
    666
    143
    Jan 6, 2003
    N.W. Louisiana
    I just installed a set of 255/60/15`s on the rear of my 81 Z. No issues.
    Kae450 likes this.
  5. Zspoiler
    Zspoiler Veteran Member
    3,778
    364
    May 6, 2012
    Federal Way, Washington
    On my 1979 Z-28 at one time I ran a P235/60/15s in front and P245/60/15s in back with no issues
    Kae450 likes this.
  6. CorkyE
    10,990
    720
    Assuming your wheels are 15x7. A lot of guys run 245/60 all the way around with no issues. I had 235/70 all around with a slight front rub, low profile bolt head took care of that. You really don't want to go over 245/60 because the outer edges of the tire tread will start pulling up, the tire is too wide for the wheel.
    Kae450 likes this.
  7. camarolife78
    camarolife78 Veteran Member
    549
    Jul 22, 2014
    Gardner, KS
    I've had 255's on the back of my car since 2003 with several different brands. No issues here from me
    Kae450 likes this.
  8. La.Z8
    666
    143
    Jan 6, 2003
    N.W. Louisiana
    I intended to add that my 1981 Z28 does have the N 90 wheels. No issues running the 255/60`s on the rear and I went with 215/70`s on the front. I didn`t want the fronts taller than the rear tires. Again no issues with the fronts either. :happy::D
    Kae450 likes this.
