tire size...will 325/50-15 fit???
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by BeefTip, Nov 28, 2012.
  1. BeefTip
    BeefTip Veteran Member
    722
    Aug 11, 2007
    Phenix City, AL
    guys im still hung up between getting a new set of 15" wheels/tires or a new look of 17/18"s...im leaning toward the old school look of the 15s...anyway, i want to fill up the wheel well, will 325/50-15 fit??? I have not seen anyone running them quite that big. M/T has a Street /drag radial that is 28x13.5 that comes out the same size, it says it will fit on a 10" rim...what do you think. Here is a link.
    http://www.summitracing.com/parts/mtt-3757r/overview/
  2. 70 gsconvt
    70 gsconvt Veteran Member
    1,095
    Sep 30, 2009
    Wadsworth, OH
    There is a thread elsewhere here regarding this size. I have that exact size on a 15x10 rim with 5-5/8" backspacing. There is a pic in the thread. It fit on the inside with a finger to spare between the tire and the leaf if I remember right. But it did stick out just past the lip of the fender.
  3. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    Search function is your friend. I have posted several pics of my car with 325/50-15's on 10" wide rims and it doesnt stick out past the fender.
    Do they fit w/o hammer work.. NO.
    Can you lower the car with them.. NO
    Look at the latest pics I posted about a month ago. I use 5" BS and I have lots of room on the inside. My fender lip is 2 fingers above the tire. It doesnt rub, but could if I hit a huge bump/ G-out, but hasnt happened yet and would be a very rare occurance. I have the stiffer Z28 leafs on the car.
    mike
  4. Ghostof76
    Ghostof76 Veteran Member
    424
    Feb 25, 2012
    Devonshire N.Wilmington,De. Hot Rods to Hell (East
    Wow! I didn't even know 15 inch 50's tires came that big!!!
  5. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,737
    500
    Aug 11, 2010
    erie, PA
  6. Tokyo Torquer3
    2,187
    Oct 14, 2003
    NJ
    Only in a drag radial.. MT, BFG, Nitto. Hoosier has them too, but their sizes run much skinnier than standard.
    Biggest street radial tire I have found that fit in a 2nd gen wheel well is the MT SR radials.. 26" or 28X12.5-15 (they fit easily and a nice tire). They are 12.1" wide. A 325/50-15 is about 13.1" sidewall width.
    mike
  7. Tokyo Torquer3
    2,187
    Oct 14, 2003
    NJ
    Here are Budnik Fontana 15X10" wheels with 4" backspace (my rear end is narrowed 1" on each side) with 325/50-15 MT ET Street Drag radials;
    It is a tight squeeze, but with some simple mods, the tire fits within the cars body line with ~3/4" clearance in the inside of the tire. This wouldn't work if the car were lowered. I would like to pull them in another 1/2-1" and use a 12" wide wheel if I could.
    mike
