tire size
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by slayer74, Oct 7, 2014.
  1. slayer74
    slayer74 Veteran Member
    166
    Jan 10, 2014
    yonkers new york
    whats the widest tire you can put on the front,i would like to go 255/60r15 on a 15x7 rim with a 4" backspace or even on a 15x8 with the same bs,someone i know said 255s will rub in the front any info is greatly appreciated thanks
  2. Gary S
    24,224
    1,695
    It depends on how your car sits. If it sits lower than stock, they won't fit. If the car sits like the early Z28s, you can fit a 245-60-15 on stock 7" wheels. If it sits like the early non-Z28 or almost all later Camaros, even the 245 could be a problem.
    You need to do some measuring before you buy anything.
  3. slayer74
    166
    Jan 10, 2014
    yonkers new york
    its a 76 looks to be stock ride height probably go with 235s to be safe and thanks for the info
