Tivo
Discussion in 'The BS Topic' started by joer, Jan 16, 2018.
  1. joer
    joer Veteran Member
    233
    Sep 25, 2008
    East Brunswick, New Jersey
    Does anybody have Tivo. How to record two shows at the same time.
  2. jimrr
    jimrr Veteran Member
    1,334
    307
    Jun 12, 2016
    sarasota
    Bump.
  3. joer
    joer Veteran Member
    233
    Sep 25, 2008
    OK whats bump.
  4. Javelin3o4
    Javelin3o4 Veteran Member Lifetime Gold Member
    1,888
    16
    Apr 21, 2004
    Concord, CA
    I have a TiVo bolt, and 2 Mini's.
    My bolt can record 4 shows at the same time. You don't have to really do anything specific. Just set the shows you want to record if they come on at the same time the TiVo will just record it. You can also flip between tuners. Sometimes I will watch something on one channel and when it goes to a commercial break I'll go to the other channel(s) and watch. You can even rewind when switching between tuners so if you had say 2 separate games on and one went to a time out or commercial and you flip to the other tuner and if you just missed something you can rewind to see what happened.
  5. joer
    joer Veteran Member
    233
    Sep 25, 2008
    I'm setting it for 3:30. Two shows. We shall see.
  6. Coadster32
    1,788
    185
    Oct 2, 2013
    Milford,CT
    Curious...is this being used for Cable, Stream, satellite, or OTA(antenna)?
  7. joer
    joer Veteran Member
    233
    Sep 25, 2008
    cable. Verizon Fios.
