TKX - Wide or Close?
Discussion in 'Transmission & Driveline Topics' started by Jack Deibel, Sep 4, 2021.
  1. streak
    streak Member
    36
    11
    Apr 27, 2021
    Yeah that looks good to me unless your tire situation changes, so maybe don't buy your diff gears until you know what tire and wheel offset is fitting in your rear.
    Jack Deibel likes this.
  2. Jack Deibel
    Jack Deibel Jack
    42
    Jan 15, 2018
    Orchard Park NY
    Good thinking!
  3. biker
    biker Veteran Member
    4,148
    2,027
    Dec 7, 2014
    Good info above, I like the 3.91 gear too.
  4. Jack Deibel
    Jack Deibel Jack
    42
    Jan 15, 2018
    Orchard Park NY
    Guys, again thanks so much for the valuable guidance. Looks like I'm all set with the transmission; 2.87 first, .68 fifth paired with a 3.91 or 3.73 depending on tire outcome..
    I learned a lot here... I started thinking I may need to do something with my truck next... :)
  5. Casenator
    Casenator New Member
    9
    Jun 12, 2013
    Utah
    Nice looking truck! if that's any indication of how the Camaro will turn out, I can't wait to see it. It will be a very enjoyable ride.
  6. G72Zed
    G72Zed Veteran Member
    3,308
    1,753
    Sep 8, 2015
    FWIW, I have used the tires actual static effective radius x2 to make the calculator more accurate as per the tire size inputs.
    I was in the same position as you were on 2 separate occasions with my build...3.73 12 bolt posi, 27.3 tire (actual was 26.5) and picked the Richmond SS 5 speed as I found the TKO600 5th option of .82 was not enough drop (18%) and the .64 was too much rpm drop (36%) and the Richmond landed at .77.
    Fast forward after my face plated days, I found myself torn again between both 5th gear options, the TR6060 Magnum gave me the .80 5th I wanted, and the .63 I craved on the higher speeds attained on the highways. I chose the "wide" option as it keeps me in the 55-72 mph zone for autocross in 2nd gear, and only use 3-4 on the road course. I do not regret going with the TR6060 Magnum one bit.
    But, it can be more work for fitment as every car is tweaked a bit different.
  7. DesmoEd
    DesmoEd Veteran Member
    1,285
    88
    Sep 9, 2009
    Frisco, TX
    I think 3:73 out back will work nicely given your engine choice
    I've got TKO 600's in both my cars - .64 OD/4.10 rear in the Camaro and .82 OD/3:73 rear in the C3 vette with 27 inch rear tires on both cars
    Im running built carbed gen 1 350's in both cars so I planned to run 5th gear above ~2200 rpm.
    I initally had 3:73 out back on the Camaro but found it a little too tall for my specific engine combo, 4.10 being much better off the line in 1st and with plenty of leg left up top to run 2500 rpm at 75 mph
    I went .82 OD on the vette as I'm running a 15 lb flywheel and the motor likes to spin - it runs 2800 rpm at the same 75 mph
    Nice truck BTW, love the wheels :)
  8. Jack Deibel
    Jack Deibel Jack
    42
    Jan 15, 2018
    Orchard Park NY
    You just convinced me to go back to my original car color... Antique white... And yes on the wheels for the Camaro.. I already have em new in the box waiting... Much like yours but 17 inch...
    Great looking car you have there!!
  9. DesmoEd
    1,285
    88
    Sep 9, 2009
    Frisco, TX
    Thanks and glad I could help
    Got the same wheels on the vette but in 17 in
    I run Nitto 255/50's on the vette to get a 27 inch height
  10. Jack Deibel
    Jack Deibel Jack
    42
    Jan 15, 2018
    Orchard Park NY
    Damn nice Vette Desmo! I'll keep those tires in mind when it's time! Thanks!
