torque arm with coil overs. yes it works
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by purpleflame, Dec 28, 2010.
  1. K5JMP
    10,216
    11
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    yeah, I'm having visions of Woody's mess when the plug welds broke, carrier rotated and it all came thru the rear floor... not cool.
  2. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    I made one, actually a couple versions, got too tight in the tunnel for it and the drive shaft. Worked very well and will go back to it if/when I go coil over, just do some BFH work on the tunnel. Made it to fit a bracket that bolted to the center of the 9".
    It did handle great on the road and hooked as well as any launch I've had with traction bars.
    purpleflame, I suggest you step back and have a look at what you're doing. The purpose of the arm is to control the diff, keep it from rotating. To do that it needs to be attached at two points, not just one.
  3. Rich Schmidt
    Rich Schmidt Veteran Member
    4,284
    40
    Mar 27, 2010
    Denville NJ
    I just wonder how with your method you would be able to adjust the instant center and correct the pinion angle. I was going to make a bracket with about 6 inches of adjustabilty at the front using a sliding front where the rod end mounts(like what is used on a wishbone) and have multiple mounting holes in the bracket that bolts to the frame. I would then need to be able to adjust the angle of the bar to keep the pinion angle correct. Obviously if I had the bar in the lowest position with the pinion angle set correct,and raised it to the top position the angle would be too high.
    A car set up with a torque arm that had the mount within 6 inches of the trans mount would almost definatly squart on launch and any car with this setup will pitch rotate a good bit. With a factory G body style 4 link the instand center is about at the center of the transmission,and those cars squat horribly and have no resistance to pitch rotation(leaving all bent out of shape) You would almost definatly need to add an air bag or spring preload to this type of setup.
  4. Rich Schmidt
    4,284
    40
    Mar 27, 2010
    Denville NJ
    Another setup would be to not make a torque arm at all,and just make a giant cal track type bar. fab one bracket that hung way low off the center section,with a single heavy wall tube that ran foward to the trans xmember and use a sliding mount on the front rod end(tube in tube slider like a wishbone uses) . Such a setup would have no real effect on the instant center,the slider could be adjustable using a jam nut so that at static height the bar wouldnt compress,but as the rear axle dropped or rose the bar could slide outward so it didnt bind the movement,but when the axle tried to twist it would stop it dead in it's tracks. Such a setup would have nearly no effect on instant center,but should stop the rear springs from wrapping any signifigant amount.
    As a side note,my 12 second street car has no traction bars at all,and runs on 10x26 slicks,and you wouldnt belive how much the rear of he car squats and the car rocks over from the torque. It leave like a G body Malibu more then a Camaro. It does work like a champ though.
  5. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
    K now after looking didnt know BMR finally built this have asked them about this idea a few times so yeah now they do it. funny thing is they only use a single bar just like I did. so now Im more prone to mine working right like I thought. notice they are using the bracket for triangulation like mine adjustable bushing up front and bolted bar in the rear,so guessing Im getting close. thinking there use of a watts link helps with twist as well? any thoughts?
  6. purpleflame
    234
    May 7, 2003
    Man why couldnt they have told me they were working on this.
    It would of saved me a ton of time and work. although most of the stuff I already had only thing Ive made is the bars and brackets. makes me feel better about the whole thing working though.
  7. retorq
    retorq Veteran Member
    4,921
    May 13, 2003
    Kingman, AZ
    Long pinion snubber!!
  8. purpleflame
    234
    May 7, 2003
    K wanna thank all you for the info and help on this I was getting frustrated and overthinking the whole triangulation thing and after more review and a great machinist friend of mine coming over we have come up with a killer idea for the torque arm gonna weld it up in the next few days and I'll post pics.
    got top and bottom triangulation and removing a heim joint or two and replacing it with bushings. will post up asap when bar is welded and in.
  9. purpleflame
    234
    May 7, 2003
    So its mocked up now and rolls on all fours, no hitting anywhere but need to still do bump stops and reinforce the top arm bracket then pull everything and clean it up for paint. still questioning the shock angle but seen other cars run them at a angle made sure both were the same. I have 6 degrees positive and negative for adjustment on arm as verified on ground with angle finder and am gonna change the trailing arm brackets to have some adjustments for anti-squat. welcome to criticism or thoughts.
  10. sweetsoul
    sweetsoul Veteran Member
    598
    Jan 12, 2010
    Liberty sc
    forgive me if i seem ignorant, but why the big bulky mess on the rearend?why could you not take the top bar back to a bolt on piece on the top of housing , and the bottom one back to the housing?the make an adjustable connection at the front to get pitch?dont cut my throat , im just asking.i been thinking of doing the same thing , i even got my 9 inch housing already.
