Torque thrust chrome plated vs. PVD finish
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by silver81, Mar 21, 2017.
  1. silver81
    silver81 Veteran Member
    154
    Mar 8, 2008
    Western Wyoming
    Looking at torque thrust d vn605 15 x 7's for my 81 z. They seem to offer the same wheel in either chrome plate or PVD finish. I understand that the difference between them is that PVD is some form of vapor deposited coating while plating is the old school dipping process. PVD is said to be more durable in harsh weather conditions as it is less subject to cracking/peeling problems. For a summers-only car is there any difference between the two? Is one shinier than the other? Is the maintenance the same for both? If they look and last the same in mild weather conditions is there any reason not to go the cheaper route? I think the PVD is about $25 cheaper than the chrome plate
  2. camaro lover
    camaro lover Veteran Member
    476
    33
    Dec 29, 2002
    Owen Sound, Ont, Canada
    i bought a set of used torque thrust 2's and they are just polished aluminum with no coating on them. they were not very old when i bought them but looked like they had been in the rain and it took a lot of polishing to get them close to 100% again. the water spots were a pain to get off of them. i wish these had a coating on them. not sure about the different coatings available on the ones you are looking for. i had a set of the american racing outlaw 1 rims for 15 years prior to what i have now and they were great. they just had a clear coat on them and i never had an issue with them. good luck with your purchase.
  3. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,980
    May 22, 2001
    Carmel, NY
    I also have the TT II's with the polished finish.
    They look beautiful all polished and cleaned up, but a royal pain in the ass to get that way. I usually dedicate an entire weekend to polishing them up in spring. By winter they look awful again...
  4. GoldenOne7710
    5,227
    667
    Jun 23, 2004
    Athens, GA
    Mother's Powerball on a power drill makes polishing a hell of a lot easier. I've got one small and one big. I thought for sure the bullet hole aluminum wheels on my truck were done...no chance to make them look good again. That Powerball made light work out of them.
  5. jthomas
    1,593
    104
    Dec 5, 2007
    NorthCentral PA
    TT's are all made in China now. The Chrome plating is thin with the copper layer hue showing through. If you compare to a triple plate chrome (US version) you can see a clear difference. The polished version has all the issues already noted. If you want a nice wheel, US made, in true US triple plate chrome, try Cragar 610C series. They are fabulous. I have had mine 6 years now and they still look new. All aluminum, chrome plated and only 18 lbs each. Check them out before you spend the money on the TT's. You can get them in 15" 17" 18" and they use acorn lugnuts. Extended shaft/acorn lug nuts also work great when the wheel stud is short like on rotors. Maintenance is simply...wipe with a microfiber cloth and done.
    https://www.summitracing.com/parts/...3m5clMyvLrhh558siNx72lomIkdXHU54RMRoCbfrw_wcB
  6. silver81
    154
    Mar 8, 2008
    Western Wyoming
    kinda what I thought, the polished are more maintenance intensive than the plated. so I think I'll go plated and I will check out the cragars.
  7. jthomas
    1,593
    104
    Dec 5, 2007
    NorthCentral PA
    The nice thing about these Cragars is they have the correct backspace for our cars. 7" wide with 4.25" backspace and 8" wide with 4.5" backspace.
  8. tom3
    tom3 Veteran Member
    12,908
    726
    Aug 1, 1999
    ohio
    Chrome on aluminum wheels generally winds up pretty much of a mess over time, and no amount of elbow grease can fix it. I'd go polished and take car of them. And check those rims for roundness and runout, not possible to get a good balance and smooth ride if the wheels are not spot on.
