torrington bearing on timing gear
Discussion in 'High Performance Modifications' started by HULKZ28, Sep 26, 2014.
  1. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
    I ordered a high perf timingng set from summit.the cam gear has a torrington ,needle bearing attached to it..has anyone used this set or a Torrington bearing behind the cam gear?my concern is if it falls apart and those small parts get in the motor..and advice is appreciated..
  2. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Been running th same one on the Racecar for years.
  3. earnhardtgm3
    earnhardtgm3 Veteran Member
    4,107
    51
    Dec 18, 2007
    Camaro Country,GA
    Running one from Lunati for my roller cam setup.
  4. K5JMP
    10,216
    11
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    I'm running one with my Reed solid roller and Jesel belt drive.
  5. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    Just a thought:
    Your sig says you have a 355 w/ a solid roller cam. Is this timing set going in that motor? Is it a factory roller block (designed to use a thrust plate/retainer between the cam and gear)? Are you currently using a thrust plate or a cam button to prevent cam-walk? I ask, because I'm thinking the torringtons would prevent the installation of a thrust plate. If it's not a factory roller block, please disregard my questions. Thanks!
  6. HULKZ28
    1,572
    Oct 15, 2005
    thanks guys...if u guys r running it, so am I..Birsman,this is a 400 block that im using the timing set on..with a solid roller..and cam button.its on the stand,in progess, forever now...the 355 in the car has a solid cam..
