traction bar question
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by HULKZ28, Sep 12, 2012.
  1. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
    Do the bars replace the stock plate when installed? If so,my stock plates include the bottom shock mount and this could cause a problem..
    any insight will be appreciated..
  2. CorkyE
    11,374
    903
    What kind of bars? I have SSM bars and they do replace the bottom mount. It shouldn't cause any issue - it hasn't for me.
  3. HULKZ28
    1,572
    Oct 15, 2005
    just lakewood traction bars.Im still researching,not sure what to get .
  4. CorkyE
    11,374
    903
    If you're driving on the street and don't want a locked up rear end, stick with something like the Eastwood slapper bars, or you can go into the high dollar region with likes of slide a link, etc. There are a lot of fast cars on slapper bars and if I had to do it again, I wouldn't go with SSM bars. They are great on the track but not so great if you want to bust a curve. You better know where the breaking point is... IMHO
  5. HULKZ28
    1,572
    Oct 15, 2005
    lakewood 21607 bars are what im looking at now...Check em out at summit and let me know what u think..I guess you use the stock bottom plate with them to retain the lower shock mount..?
  6. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    3,368
    194
    Aug 5, 2007
    Various barns in N. IL looking for chit.
    No, the Lakewood ones do not replace the bottom plate. I just put mine on last week. Only issue is the driver side sits back about an 1'' further due to the shock mount. No biggy. :cool:
    Not sure what Corky means by risking a locked up rearend.:confused:
  7. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    The ones I had on my nova replaced the plates and worked fine
  8. Odin
    Odin Member
    40
    Sep 15, 2003
    He is referring to the fact that the SSM bars effectively remove the front half of the rear spring and make the back pretty stiff.
  9. CorkyE
    11,374
    903
    Yup - not much give back there. If you break the rear end loose going around a curve, hang on...
  10. Odin
    Odin Member
    40
    Sep 15, 2003
    True enough but isn't any limited slip car going to become what I call "a handful" in that situation? Maybe the SSM bars make it easier to break em' loose in a curve?
    I also have SSM bars on my '72. They lifted the rear slightly and helped with a rubbing issue on the passenger side. I've been happy with mine but I've had them a long time. Today I would check out the other offerings but there doesn't seem to be a clear cut winner that doesn't have drawbacks. Personally I don't like the look of slapper bars.
