Traction bars- UMI vs CPP vs Caltrac, etc
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ULTM8Z, Sep 18, 2020.
  1. SPG
    SPG Bumblebee Builder
    1,087
    390
    Sep 1, 2018
    Sacramento
  2. Lowend
    16,397
    1,224
    Mar 25, 1999
    San Jose, CA, USA
  3. SPG
    1,087
    390
    Sep 1, 2018
    Sacramento
  4. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,645
    1,060
    Mar 27, 2016
    NY
    It says this however about the CAT5 bearings
    Works better with flat springs, no overly arched springs
  5. muscl car
    23,288
    1,730
    Jul 8, 2001
    Hendersonville Tennessee
    Go with Calvert racing Cal Trac bars !!!
    czizza and ruthlessz28 like this.
  6. Bandit723
    Bandit723 Veteran Member
    3,562
    641
    Oct 1, 2016
    Waupaca WI
    Ditto ^^^^^^
  7. biker
    biker Veteran Member
    3,558
    1,625
    Dec 7, 2014
    Yes. Others have said the same, and I dont doubt they were flawed. I had mine in for 5 years without issue, but I never had any traction, and I likely didnt put the miles on that you did. I did however probably put on 500 miles of burnouts and donuts which I couldn't do without them!
  8. DB Z28
    DB Z28 Veteran Member
    646
    97
    Nov 30, 2003
    Fond Du Lac
    Go with Calverts racing Cal track bars
    Bandit723 likes this.
  9. G72Zed
    G72Zed Veteran Member
    2,919
    1,423
    Sep 8, 2015
    Those UMI bars look interesting, but I like the spherical bearing in front. Following this thread to see how it goes.
  10. GoldenOne7710
    5,556
    835
    Jun 23, 2004
    Athens, GA
    If the car will be more street driven, I'd go with Slide-A-Links over the Caltracs. You can unload the SAL's to the point where it will allow for full suspension travel. At the track...just tighten and preload where you want it.
    The Caltracs are designed to achieve the same in regard to axle and leaf twist, but you are limited on how much load you can take out of them so the ride quality suffers on the street.
