Traction bars- UMI vs CPP vs Caltrac, etc
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ULTM8Z, Sep 18, 2020.
  1. muscl car
    23,346
    1,789
    Jul 8, 2001
    Hendersonville Tennessee
  2. BonzoHansen
    20,812
    1,835
    Jun 1, 2005
    Scott from Hamilton, NJ
    The umi 71 camaro last weekend
  3. czizza
    czizza Veteran Member
    1,131
    118
    Jan 8, 2004
    N. Massapequa, NY, USA
    Had SSM Bars like slappers, then got the Calvert Caltracs and they are awesome and a lot better. If you preload your suspension it will also stiffen up your suspension around turns as well. They are not just for drag racing.
    muscl car likes this.
  4. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,652
    1,072
    Mar 27, 2016
    NY
    What tires are you using, and what transmission? Really nice run!!
    UMI Tech likes this.
  5. Cardinal
    8,338
    62
    Jun 22, 2003
    Endicott, NY
    I vote for CalTrack bars. Everyone that I've talked to over the years said they're the easiest to set up and work.
  6. Coadster32
    2,302
    367
    Oct 2, 2013
    Milford,CT
    That guy can drive!!
  7. GoldenOne7710
    5,583
    854
    Jun 23, 2004
    Athens, GA
    I've had both. I used the Caltracs first. I ended up giving them away due to the harsh ride. Put on SAL's and never regretted it. Car launches equally as well with both, but the street ride quality of the SAL's on MY car was night and day. Your mileage may vary.
  8. BonzoHansen
    20,812
    1,835
    Jun 1, 2005
    That's the umi camaro. Iirc its a magnum and bfg rivals.
    [email protected] likes this.
  9. DB Z28
    DB Z28 Veteran Member
    646
    98
    Nov 30, 2003
    Fond Du Lac
    Most of them look like they tried to copy Calverts design to make it better
    Bandit723 likes this.
  10. muscl car
    23,346
    1,789
    Jul 8, 2001
    I use this tuning / set up info for my Calvert racing Cal Trac bars
    FRONT: make sure the front control arm are not binding. this is one of the biggest issues. you can do this with after market bushings or control arms or just elbow grease. the control arms should fall on there own without having to push them down. the front springs need to be of a drag style that will give you the best weight tranfer you can AND MUST HAVE ATLEAST 5" OF UPWARD TRAVEL IN THE FRONT END. shocks should be of a good drag style i like d/a afco's. AFTER DOING ALL THE ABOVE SET THE SHOCKS AT FULL LOOSE FOR THE FIRST FEW RUNS.
    2. FOR THE REAR same thing binding is the number 1 issue most the time it's in the shackels and the front leaf spring mounting bolt.. every car i see the bolts are over tightened you should be able to push the rear down 5-6" easy without the shock or caltrac mounted. lube all bushings well and don't over tighten. know that there’s no binding, any adjustment later will work..
    3. i always start in the upper hole and preload of 1/16 gap. this will give you a lot of pressure over the rear tire. shock settings ON REAR, i always start at full tight on extension... know that the car is setup for a test pass have someone video it.. THE CAR WILL DO ONLY A few THINGS NOW.
    a. IT WILL HOOK AND PULL A HUGE WHEELIE
    - IF IT HOOKS AND PULLS A HUGE WHEELIE THEN TIGHTEN THE FRONT SHOCKS THIS SHOULD BE THE ONLY REASON TO TIGHTEN THE FRONT SHOCK
    b. IT WILL HOOK AND DO WHAT YOU NEED
    c. IT WILL HOOK AND pull left or right
    - IF IT HOOKS AND PULLS TO THE RIGHT OR LEFT THEN PUT A LITTLE PRELOAD ON THE SIDE IT PULLS TO.
    d. IT WILL HOOK AND SPIN 20FT OUT
    - IF IT HOOKS AND SPINS 20FT OUT START LOOSENING THE EXTENSION ON THE REAR SHOCKS 1-2 CLICKS AT A TIME TO IT HOOKS AND STAYS ON THE REAR TIRE.
    e. IT WILL KILL THE REAR TIRE BY HITTING IT WAY TO HARD
    - IF IT KILLS THE REAR TIRE YOU NEED TO PUT THE BARS IN THE LOWER HOLE AND ADJUST THE SAME AS YOU WOULD IN THE UPPER HOLE.
