Traction control
Discussion in 'High Tech Retrofits' started by 1320feet, Jan 31, 2021.
  1. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    I'm just using duty cycle with a 3 port mac to control boost right now. It was super simple to get my feet wet with the whole turbo deal. This spring I'm stepping up to dual 3 ports with dome psi. The dominator is great for a dummy like me. The safeties have saved me from eating a piston many times. All the tuning is done by my dumb ass and I went 10.11 @ 137.
    7500 miles on a cam and springs gen3 junkyard 5.3 with no prior tuning experience and it's still together.
    A turbo car does NOT pedal like an N/A car. When you get into wastegate boost, 50% tps feels exactly like 100% so you have back wayyy out of it to feel the power drop off or stop the tires from spinning.
    Tire selection is huge. With an average street tire (300+ treadwear) you can do rolling 50-60mph burnouts at 500whp with ease. I'm on Nitto 555s for the street. They hook a ton better but I can still smoke them at 50mph if I brake boost.
    Right now I just use F/R wheel speed vs timing for t/c. I can't cut a 1.3 on the street but it sure does help at 40mph+ if things get a little sidewaysie when you're not expecting it.
  2. DB Z28
    DB Z28 Veteran Member
    640
    90
    Nov 30, 2003
    Fond Du Lac
    When I went to Holley EFI school for the Tier 1 class You will be amazed what the Holley Terminator X and the Dominator can you can do for traction control and Automatic transmission control. to lower your et times its unreal . I think this is the best system out their. You can have the traction control come on at any speed so you don,t throw it a way on the top end.
    slamdik likes this.
