Tranny cooler- hoakie line connections
Discussion in 'Transmission & Driveline Topics' started by need-for-speed, Nov 4, 2014.
  1. need-for-speed
    need-for-speed Veteran Member
    821
    38
    Feb 7, 2003
    Conroe, TX
    Thanks dog ! I'll see if I can find some bulk ps hose.
  2. need-for-speed
    821
    38
    Feb 7, 2003
    Conroe, TX
    Thanks Rich ! good to know on the braided hose (seeing as how I'm cheap anyway). I'll use power steering return line hose per dogwater. And it's cheaper than braided too!
    win - win !!
  3. need-for-speed
    821
    38
    Feb 7, 2003
    Conroe, TX
    Thank you bondo. You've given me some good options to think about. In the pic below, it shows I have the original line coming from the tranny with the male fitting that used to screw into the radiator tranny cooler. Can I buy a (female) fitting that screws onto that with barb on the other end?
    Option 2:
    option 1 above leaves me with about 18 - 20 inches of rubber line between the OEM steel line and the cooler connections. Should I go to the trouble to fab a steel line that gets me to within 3 inched of the cooler? If yes, do they make a "coupler type fitting that I could use to join the original steel line (with it's male fitting) to a new piece of steel line?
  4. BondoSpecial
    8,694
    Sep 20, 2004
    Connecticut
    You can use a compression fitting to join steel to steel if they are the exact same OD. Most people use the crappy brass unions the auto parts store sells. I would not. I would buy some steel Swage lock type compression fittings from McMaster or MSC or Grainger, which will be rated for way more pressure than you need, just for safety's sake. The brass ones are usually rated for very low pressure.
  5. need-for-speed
    821
    38
    Feb 7, 2003
    Conroe, TX
    Thanks bondo. We use swagelok at work so,I can get a discount. I've been avoiding cutting off the flared end of the OEM line, but maybe that would be the cleanest way to do it. Hopefully the OEM line is still perfectly round.......
  6. BondoSpecial
    8,694
    Sep 20, 2004
    Connecticut
    the other option to make a good steel to steel connection is keep the flared end, and flare another piece of steel, and then use a flare union.
  7. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I'm a huge fan of the -6 teflon lines, and a cooler with threaded ports.
    Good luck.
  8. need-for-speed
    821
    38
    Feb 7, 2003
    Conroe, TX
    Thanks Bondo. That sounds like another good option. I would like to run some additional steel line so that I only have 3 or 4 inches of rubber
    :cheers:
  9. need-for-speed
    821
    38
    Feb 7, 2003
    Conroe, TX
    Good to know. Thanks !
  10. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    This.
    Or if you insist on the low buck approach, connecting metal lines with rubber line, at least slightly 'bell' the ends of the steel line with a double flare tool so the clamp CANNOT come off over the belled end.
    It took me two complete, trans draining hose blow offs to learn that. Now, all threaded and proper connections. I don't mind using brass, I never use teflon tape though, only paste (pipe dope).
