Trans Crossmember?
Discussion in 'Transmission & Driveline Topics' started by Lars_2Gen, Mar 21, 2018.
  1. Lars_2Gen
    Lars_2Gen Veteran Member
    706
    218
    Dec 29, 2017
    Fullerton, CA
    I've searched and not found the answer to this seemingly simple question... What cross member do you use for a TH350 transmission? It seems like all the parts places sell is the TH400 crossmember or the manual trans crossmember. The car I bought didn't come with one, so I need to get this figured out.
  2. Dave Nelson
    Dave Nelson Veteran Member
    5,071
    3,974
    Dec 19, 2003
    Vineland N.J USA
    The cross member for the TH350 should be the same as the 4spd.
  3. 74BIBELOT
    74BIBELOT Veteran Member
    865
    57
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    41CAE3F6-959F-4BBB-8042-A1076D526D90.png Hope this helps:
    Lars_2Gen likes this.
  4. Lars_2Gen
    706
    218
    Dec 29, 2017
    Fullerton, CA
    Awesome, thanks!
  5. CorkyE
    11,171
    821
    Wish you were close to GA/TN, I would give you one. If you post in the Swap Meet section or CL, you might get one local and cheap.
  6. harbone66
    3,498
    287
    Feb 15, 2011
    Central Illinois
    On my old 73 Camaro that was converted from a manual trans to a TH400, the manual trans cross member had the mount bracket cut off and welded to the backside and it worked fine
  7. mrdragster1970
    7,821
    507
    Apr 12, 2007
    That's what the speed shop told me to do when I upgraded to the 400, but I just bought one, couldn't weld back then.
  8. camaro71/holland
    1,449
    176
    Aug 27, 2003
    The Netherlands
    +1 on a change from TH350 to a TH400
  9. Lars_2Gen
    706
    218
    Dec 29, 2017
    Fullerton, CA
    Would you be willing to ship it if I paid for it plus a bit for a few beers?
  10. 71RSLS
    71RSLS Veteran Member
    766
    176
    Dec 5, 2017
    Prairie City, Ia
    I'm getting ready to do a 4 speed swap on my camaro. Mine had a powerglide in it originally. Is that crossmember the same as a TH350 one? I didn't see it listed in the pic.
