RS_SS350
Hi all,
A long while back when I installed my BTO 2004r, I installed a temp sender in the pan. When the car is running, the temp slowly climbs up to max temp on the gauge. The fluid is not burning, so I am definitely getting an inaccurate read. From what i've read, it would be something that happens if something is grounded.
The wire from the sender through the firewall is in good condition and I'm not seeing it touch the chassis or grounding anywhere. The sender is in the fitting that's bolted into the pan, i used plumber tape to make sure it doesn't leak. Could this be the problem? ANy other suggestions on getting this gauge to read accurate?
Thanks!
Rob
Thanks!
Rob
