Transmission Cooler Plumbing Fittings
Discussion in 'High Performance Modifications' started by reinhardt79, Dec 24, 2017.
  1. reinhardt79
    reinhardt79 Veteran Member
    858
    May 12, 2002
    VA BCH, VA
    I would like to plumb a diverter valve into the inlet line of the external cooler. Flow through the stock cooler then the external in the summer. Flow through the stock cooler only in the winter. I am having trouble finding a three way valve and a tee. Found them in brass, but would like something that will match in with the rest of my fittings.
  2. Zspoiler
    Zspoiler Veteran Member
    3,714
    341
    May 6, 2012
    Federal Way, Washington
    Check Napa ,A pluming store and ore Hardware store.
  3. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I know they make red & blue AN 1/4 turns and stainless steel 1/4 turns. Not sure which brand.
    Are you using hard line or -6 AN.
    That's a very smart idea, I did a similar deal on my neighbors bulldozer.
  4. reinhardt79
    858
    May 12, 2002
    VA BCH, VA
    A combination of both. Hard line from trans to front of engine, then -6 to coolers.
  5. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Might be easier to just swap the lines, and make a jumper??
    The AN stuff is easy to do quickly without making too big of a mess??
    I would swap the top hose, and skip the valve.
    Good luck which ever direction you go.
  6. reinhardt79
    858
    May 12, 2002
    VA BCH, VA
    Well, I have to come clean. This isn't for my 79 Camaro, it's for my jeep. I installed the external cooler for when I take the jeep wheeling. So, I'll need the external cooler on and off year round. If it were seasonally, I would definitely take your advice. But, I don't want to swap lines around every time I want to go wheeling.
  7. PalmbchZ28
    PalmbchZ28 Veteran Member
    772
    327
    Jan 29, 2017
    West Palm Beach Fl
  8. PalmbchZ28
    772
    327
    Jan 29, 2017
    West Palm Beach Fl
    If you don't want electric .. remove the head and put a wrench on it ??
  9. mrdragster1970
    7,821
    507
    Apr 12, 2007
    OK, I thought it was for something you wanted to look nice.
    For a toy like that, just stick a 1/4 turn in there like I did the bull dozer.
  10. 77 cruiser
    77 cruiser Veteran Member
    564
    30
    Nov 17, 2006
    Frostbite Falls MN
    Just cover the cooler in the winter. How cold does it get there?
