Transmission pairing with a mild modified supercharged SB
Discussion in 'High Performance Modifications' started by NM1989, Dec 4, 2017.
  1. NM1989
    NM1989 Member
    33
    Sep 23, 2017
    Nebraska
    I am looking to upgrade my transmission to a TH350 that can handle a mildly modified SB 350 or 383 with a Weiand 177 supercharger. For round numbers sake, I plan on making 450-500hp. Eventually I want to buiid a SB 350 or 383 but I want to posture my drivetrain to handle the upgrade. There are tons of forums on Super Chevy with Weiand reviews but I can't find info regarding transmission pairing. Any thoughts are appreciated.
  2. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Weight & application makes a huge difference.
  3. SRGN
    SRGN Veteran Member
    681
    239
    Feb 20, 2009
    Central NJ
    This. Post up the rest of your combo.
  4. NM1989
    NM1989 Member
    33
    Sep 23, 2017
    Nebraska
    Its going into a 1979 Camaro with a 4.10 gear. I currently have a SB 350 4 bolt main with a Comp Cam CL12-242-2 and a 2700 stall in a TH350. Heads are cast iron rebuilt rebuilt heads (can't remember valve size--rebuilt the motor with my dad ten years ago). The current TH350 has seen better days and want to upgrade to something I can grow into from a HP/TQ perspective. I don't plan on running a trans brake. Goal is to have an occasional street/strip car eventually adding a Weiand 177.
  5. Zspoiler
    Zspoiler Veteran Member
    3,824
    380
    May 6, 2012
    Federal Way, Washington
    Check with your local transmission shop .and or transmissions companies such as Art Carr transmissions,TCI,etc.
  6. Z28zz383
    Z28zz383 Veteran Member
    828
    12
    May 11, 2012
    Florida
    I am on my 2nd 350 turbo since my motor swap from stock power. I now have about 425hp 460tq. 1st one I had built blew out fairly quickly, and I mean blew up. It blew the sprag , pump and the clutches to pieces. Got a new trans guy! The second one was built with all new parts, billet drum, hardened sprag , new clutches with a larger capacity pan and a big hayden cooler using a magnetic filter. No trans go shift kit stuff, just a well built tranny. It shifts firmer than ever and has so far held up for 5yrs. If you get the right tech a modded 350 will last with up to 500hp according to my trans guy. After that a built 400 would be better. Also using a PTC converter 2800 stall with no prob for 5 yrs. jm2cts
    NM1989 likes this.
  7. vegas1974z28
    4,663
    124
    Jan 10, 2002
    Las Vegas,NV
    This is always the right play....however... I ran a 177 ontop of a 468 and a turbo 350 (upgraded) it pushed me into the 11's with few problems. I eventually went to a 400 with a trans break
  8. NM1989
    NM1989 Member
    33
    Sep 23, 2017
    Nebraska
    Awesome! So I was looking at the TCI Streetfighter and it specifically says "non-supercharged applications" in the description but in the same paragraph it says it's rated between 400-775hp. I was wondering if there was a weird consideration for this specific trans with regard to blowers. It's within my budget and Jegs offers a kit with trans cooler and torque converter.
  9. NM1989
    NM1989 Member
    33
    Sep 23, 2017
    Nebraska
    Also, you all are correct. I need to give the experts at TCI/B&M (whichever one I go with) a call to see what they recommend.
  10. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I don't recall ever having to do something different for a blown application compared to N/A or N2O???
