Tremec 3650
Discussion in 'Transmission & Driveline Topics' started by purpleflame, Apr 1, 2008.
  1. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
    Is the tremec transmission in the mustangs a good transmission and will it go int my 72 camaro if so what is needed: bellhousing driveline etc... any info would be great.
  2. BonzoHansen
    20,236
    1,512
    Jun 1, 2005
    Scott from Hamilton, NJ
    IIRC ford uses a 10 spline input shaft, so that could present an issue.
  3. tom3
    tom3 Veteran Member
    12,958
    764
    Aug 1, 1999
    ohio
    These need to be modified to fit the Chevy. Front bolting is a bit different, longer input shaft, throwout bearing sleeve is different. Tranny is longer than the four speed. A couple companies sell converted trannys, fit well and they are a really good transmission with the low first gear and the OD.
